Abs light - Ford Powerstroke Diesel Forum
Old 04-04-2011, 07:35 AM
Abs light
Why would my abs light be on all the time I have edge chip but I didn't think that make a dfference I also replaced the sensor in the pumpkin no change the light comes on right when you start the truck any ideas any fixes would be helpful
Old 04-04-2011, 07:47 AM
sounds dumb but check your brake fluid if you haven't yet. Same thing used to happen in my old explorer, might save you some time if you haven't checked already.
Old 04-04-2011, 02:53 PM
Get a scan done to make sure a wheel speed sensor did not go bad on you. Check to make sure both sides are plugged in also. It's the wires coming from your front wheel bearing/hub assembly. Goes to just behind your inner fender liner, and the plug is right there.
