Frustrated - Oil Leak
well replaced my turbo and pedestal o-rings Friday. Seemed to fix my oil leak, drove it friday and saturday. went to church this morning and there was a spot of oil. It is not leaking as bad as before but still enough to frustrate the heck out of me. Climed up under the hood and the valley is dry. went under the truck, cannot find the source of the leak. it is dripping from around the fly wheel inspection plate.
any ideas on what to look for next. Wishfull thinking is that it is just some left over stuff that has heated up and started dripping. but, that is not likely. any advice appreciated. may just have to break down and take it to a mechanic shop. |
dont do that! nmy truck has moisture in that spot as well when i pulled my turbo it had no signs of oil leaks, wondering if it could be a leaking pedestal?
EBPV actuator rod?
checked that today and looks good. top of engine is clean. maybe rear main seal? I spent alot of time this evening with a light and mirror and cannot pin point it. I think at this point I am gonna have to turn it over to the professionals. i hear there is a good diesel shop close diesel unlimited in alabaster.
my ebpv rod was leaking and it was VERY hard to tell, they tend to crap out, i dont have one any more though lol whats an ebpv
update... there was water on top of the block when I was checking for the oil leak, I just over looked it and thought it was from me washing under the hood after replacing the o-rings. well tonight I stuck a wrag down in there to dry it up, and it is not water, it is diesel fuel!
So i think maybe the fuel is running down the back of the block and mixing with the residual oil from the turbot leak which makes it look like oil. I spent alot of time but cannot see a drop from the fuel bowl. the fuel is puddled in the valley directly below the fuel bowl. I watched it while idling for about 5 minutes and never saw it drop. so looks like i have another leak to fix. i know there are alot of o-rings and places for fuel to leak, any advice on figuring out where it is coming from. thanks for everyones input on this site. |
Ok I have read these guys talk about the fuel bowl drain leaking. I think it is a simple o-ring fix. Try to search it on this forum.
