HELP HELP HELP - Ford Powerstroke Diesel Forum
post #1 of 20 Old 07-25-2007, 06:44 PM Thread Starter
dieselpower99's Avatar
HELP HELP HELP
ok i have a 99 7.3 man. 6 speed and i got the truck and the clutch was not there it felt like so i replaced master slave cylinder there is a rod that goes down into the bell houlsing and and a strap like thing that goes over it so the clutch will have back pressure so it will push clutch back out well i have replaced it and it broke again so is there a better part to buy any suggestions i am taking it to ford tomorrow the part itself is 165 plus 45 for them to look at it
EDGE Evolution 2, custom intake 4 in, 4 inch down pipe, duel exhaust, WW,
dieselpower99 is offline
post #2 of 20 Old 07-25-2007, 06:59 PM
did you replace the whole assembly?
that would be the resevoir,piping and slave cylinder that connects to the bellhousing.
It comes as a complete unit from Ford and it is pressurized so there is no bleeding involved(that is another issue) but we won,t go there.
Merv Dessent
merv dessent is offline
post #3 of 20 Old 07-25-2007, 07:07 PM Thread Starter
YEAH replaced it all 160 dollars
post #4 of 20 Old 07-25-2007, 07:12 PM
if your talking about the two little straps on the rod that goes into the bellhousing....those are designed to break, they have nothing to do with the pedal return process or "backpressure". THey hold the rod in place during instillation and shipping and the first time you step on the pedal, those tangs on the little plastic straps break, allowing the rod to come in contact with the clutch fork....if i read your post correctly, you dont have a problem....that is normal...
mschn99 is offline
post #5 of 20 Old 07-26-2007, 04:31 AM Thread Starter
**** i thought that was right no there is a problem may be the clutch fork is not pushin in on it far enough
post #6 of 20 Old 07-26-2007, 04:32 AM Thread Starter
how do i fix that
post #7 of 20 Old 07-26-2007, 05:14 AM
Jeff_Northon's Avatar
Or your clutch cover plate is starting to break down.
Jeff_Northon is offline
post #8 of 20 Old 07-26-2007, 05:22 AM
The cluch forks in these do break sometimes....
mschn99 is offline
post #9 of 20 Old 07-26-2007, 05:50 AM Thread Starter
see my boss told me it could be that the throw out bearings did somthing now the pressure plate ****ed up and fork dont have any pressure
post #10 of 20 Old 07-26-2007, 06:00 AM
Stupidity pisses me off
sevenmalards's Avatar
Quoted: 9 Post(s)
I think if it was your throwout bearing going out it would still make full contact, it would just growl really loud every time you depressed the clutch petal, that usually is the "signature diagnosis" of a bad bearing
2006 F350 CREW CAB LONG BED KING RANCH
99.5 F350 Super Cab Long Bed, Dually.
SOLD
Originally Posted by SMKSTAX View Post
You are not right man, but i still think your funny as hell!
sevenmalards is offline
