Grey Smoke - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-28-2011, 08:14 PM Thread Starter
lcducote's Avatar
Quoted: 4 Post(s)
Grey Smoke
been getting some oil smoke on startup lately? trucks also having a harder time starting these days. anything i should be looking into or is thiss normal for 152,xxx miles?
2002 F-250 POWERSTROKE 4X4
BANKS 4" Turbo-Back w/ Power Elbow
Converted from 3/4 to 1TON
Napa 6637 DIY Intake
6.0 Trans. Cooler
Dipricol Gauges
Warn Hubs
TW 6 Pos.
And Some Other Boring Stuff
THANK GOD FOR YOUR BLESSINGS EVERYDAY
lcducote is offline
post #2 of 5 Old 03-29-2011, 05:38 AM
ridiculously_necessary's Avatar
ohm out your glows and test your relay (sticky up top) is where i would start. and does your starter seem to spin reasonably fast? whats your outdoor ambient temp when you start?
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #3 of 5 Old 03-29-2011, 06:11 AM
CowboyCody's Avatar
Glow plug system first, maybe fuel filter next start with the simple stuff first anyway. at that mileage your truck is just getting broke in If its cold they will smoke some on startup but if it is starting harder than normal there must be something wrong(not mileage). You probly wont have to go this far but my dad had to replace his valve cover gaskets along with his glowplugs once on his '95, the plugs were almost burnt off. something to look at anyway while your in there
Originally Posted by madpowerstroke View Post
Try spinning a turbo with compressed air and hit it with diesel clean as you inhale at the turbo outlet, I call it a turbo bong.........that's some good stuff, makes you come up with all kinds of crazy ideas.
2010 F450 Super Duty Lariat Ultimate, 140,xxx Miles. 5" DP Back. Black Maxx. AFE Pro 5R Stage 2. ARP studs new heads and gaskets.
CowboyCody is offline
post #4 of 5 Old 03-29-2011, 12:06 PM Thread Starter
lcducote's Avatar
Quoted: 4 Post(s)
probably plugs. just put a new relay on last winter. rebuild fuel bowl and put new filter in in december. thanks
6.0 Trans. Cooler
Dipricol Gauges
Warn Hubs
TW 6 Pos.
lcducote is offline
post #5 of 5 Old 03-29-2011, 01:12 PM
you know to only get motorcraft ZD-11 or beru plugs right?
-Matt
DIY 6637
Marinco Mod
