Super Duty Shock Replacement - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-27-2011, 01:35 PM Thread Starter
Mitch
thebierguy's Avatar
Quoted: 89 Post(s)
So I was driving today and hit a bump that snuck up on me. I heard a clunk from the front end. From then on, at every bump, I hear a small clunk coming from the front passenger side. When I got to my destination, checked the shock and I can move it side to side at the joint of the boot and the body - needless to say it is shot. So now I am in the market for new shocks - I probably should do all 4 but would hurt to do just the front ones to save some cash now?
I have read that Bilstein's are a good shock for these trucks, any other brands I should look into purchasing?
Would NAPA supply a good shock for a replacement?
If you have any suggestions on where to buy them from, please let me know.
Also, are they hard to replace. Unbolt the old one, and bolt the new one in, making sure that I keep it compressed until I need to bolt it in. Can I leave the tires on the ground? I have never changed them before.
Thanks for all the advice in advance!
Mitch
2006 Ford F-350 6.0 Crew Cab Lariat Short Box./4" exhaust/SCT X4 7015 (White Noise)/Autometer Boost and Fuel Pressure(Strictly Adapter)/Edge Insight CTS2/FICM Repair.com Complete Wire Kit/08+ Rear Differential Cover/B&W Goosneck hitch/Sinister Coolant Filter/High Idle/Blue Spring/Purchased 2/28/2014
2002 Ford F-350 7.3 Crew Cab Lariat Short Box, SOLD 2/24/2014
thebierguy is offline
post #2 of 13 Old 03-27-2011, 02:57 PM
Quoted: 3 Post(s)
go blistens!!
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #3 of 13 Old 03-27-2011, 04:25 PM
Quoted: 177 Post(s)
Feedback Score: 3 reviews
If you want to save some money from the Bilsteins, and still want a quality lifetime gas shock, look at the Monroe Reflex.
For a little over $150 I got 4-shocks and steering stabilizer delivered from Amazon. I think the fronts were like $37ea.
NoRalPh is offline
post #4 of 13 Old 03-27-2011, 04:36 PM
codysweat's Avatar
i have monroe shocks rite now the've been through a lot last 40k and there actually still holding up.
1/30/98 EARLY 99 7.3 F350 DRW CC 4X4 4R100 3.73 LARIAT
codysweat is offline
post #5 of 13 Old 03-27-2011, 04:44 PM Thread Starter
Mitch
thebierguy's Avatar
Quoted: 89 Post(s)
Initial reading has lead me to Bilstein's but when reading more in depth, I have heard that the Monroe Reflex's are decent as well -- and a bit cheaper which is what I am going for. I am looking for a good shock better than a worn out stock shock - there are Rancho's on it right now which I think are stock with 87k on it. The rears have been making noise with a load of fire wood on and now the front right is shot. I probably will be going with the Monroe Reflex's which I believe I can get from NAPA or Oreily's - need to do this tomorrow so I am not running without a good shock for too many miles.
Mitch
post #6 of 13 Old 03-27-2011, 07:57 PM
They're easy to replace, but you may need new bolts for the bottom attachment, my front ones were really worn down when I replaced my shocks last year. You'll have to get the bolts from Ford, I don't think Napa or other stores carry them. Oh, the front and rear bolts are different.
I got the Monroe Reflex and really like them.
99 F350 Crew Cab Long Box 4X4
311 k and
PHP Phoenix - 5 positions
DIY NAPA Intake Mod
Marinco Mod
MtPaul401 is offline
post #7 of 13 Old 03-27-2011, 08:23 PM
chillls's Avatar
you will be able to change them with the tires on the ground
Dave
2002,7.3L,6sp,cc,lb,xmonitor,1705,zoodad,AFEstg2, wicked wheel,hpx ss line,straight pipe,325/65r18 mtz,kmc 18x10,6.5"procomp lift & track bars,firestone bags,viair 480,5g tank,train horns,70g transfer tank,leer shell,12k warn & hidden bumper kit,05-07 H-D headlights,35W 5K HIDs in head/fogs
chillls is offline
post #8 of 13 Old 03-28-2011, 08:42 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Yes but easyer if you remove the front tires..If you would like a quote on Bilsteins PM me.
CT Performance, Inc. is offline
post #9 of 13 Old 03-29-2011, 11:44 AM Thread Starter
Mitch
thebierguy's Avatar
Quoted: 89 Post(s)
I bought the reflex shocks for the front and am going to put them on tonight. Just a quick question: Is the bigger tube on the top or the bottom when installed. The current stock ones, the bigger tube is on the bottom, but I am not sure what the proper orientation is for the Reflex's. Thanks!
Mitch
post #10 of 13 Old 03-29-2011, 03:05 PM
Quoted: 177 Post(s)
The BIGGER tube was on the Bottom?
Wouldn't that mean it would act like a "cup" and hold water?
Could someone have put your shocks on upside-down?
NoRalPh is offline
