Best place to install the boost sensor? - Ford Powerstroke Diesel Forum
Old 03-22-2011, 07:30 AM
I'm getting ready to install either Iispro or AutoMeter Z's pillar gauges plus do the AIH delete. I see where there is a plug from DP that allows you to plug in the boost sensor in the AIH hole. I'm thinking it's a win / win mod. Is that the optimum place to go in?
I really rather not have to drill another seperate hole in my housing when there's one already there.
Old 03-24-2011, 04:43 PM
[IMG][/IMG]
Old 03-24-2011, 04:50 PM
Feedback Score: 5 reviews
I just drilled and tapped the spider... it was really easy, (way more than I thought) and didn't take too long, it's aluminum, so it cuts like buttah!
Old 03-24-2011, 05:32 PM
^ Same. Although I was told it was magnesium, not aluminum. Either way it is a soft metal, so don't over tighten the fittings.
Old 03-24-2011, 10:33 PM
I went on another site and within an hour got multiple feedback saying the existing AIH hole is the best, most logical place to connect the boost sensor.
Old 03-25-2011, 04:13 AM
I saw you over there...
Old 03-25-2011, 05:13 AM
Have you figured out what model of engine the drain plug is from? or are all the Cummins plugs the same size?
Old 03-25-2011, 06:27 PM
Hey, what an inforamtive response
Old 03-25-2011, 08:07 PM
Excuse me? I'll type slow so you can follow along.. Did you happen to see my first post on this thread? It’s a rather large picture with a cat? Said Picture, stated I was interested in the answer you found. My next post stated that I saw your duplicate thread over at PSN, what I did not say was that I could not find the thread again. So I came back and asked you "Have you figured out what model of engine the drain plug is from? Or are all the Cummins plugs the same size?" I thought it was rather strait forward question. I didn’t know that I was intruding on your thread, I guess I’ll just start a duplicate thread asking the very same question you did.. Have yourself a great day, and.
Old 03-25-2011, 08:28 PM
spool up that turbo!!
i did mine in the AIH delete plug and works just fine
