CCV Mod Benefits? - Ford Powerstroke Diesel Forum
Old 03-21-2011, 04:32 PM
CCV Mod Benefits?
Are there any benefits to this mod besides the fact that its the way International intended it to be made?
Old 03-21-2011, 04:54 PM
To add to your questions, besides the oil on the IC boots being annoying, could the stock configeration be emissions related? I know the newer engines can't vent directly to atmosphere.
Old 03-21-2011, 04:59 PM
Got Whistle?
Feedback Score: 5 reviews
The main reason being to clean up the engine compartment, keep the IC boots clean, keep them from possibly blowing off, and to keep oil out of the intake.
Old 03-21-2011, 06:46 PM
and to keep the oil out of your intercooler.
Old 03-21-2011, 07:15 PM
Definitely good benefits, i havent missed the oily mess in my IC and intake..
the way it should be!
Old 03-23-2011, 06:55 AM
CCV Question
Does the stock orientation lube the Turbo in any way??? Was wondering this, but not sure the path as this is my first PSD.
Old 03-23-2011, 09:10 AM
nope. the pedestal does that.
Old 03-23-2011, 01:14 PM
I am about to ccv my 2001 and from what I here you also want get the oily mess at the back of the engine and oil pan that makes you think the rearmain is leaking.
Old 03-24-2011, 06:29 AM
There are oil leaks from the top of the engine that drain down the back of the block and have people, incorrectly, diagnose a bad rear seal BUT, not from the CCV...
The CCV is supposed to be a closed system and you won't see external leaks from it other than around the IC boots
Old 03-24-2011, 11:34 AM
Then what is leaking filling the valley with oil and leaking down?
