Brake rotors warped after 6,000 miles… What rotors are the good ones? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-17-2011, 07:17 PM Thread Starter
The post says it all did the brakes on the truck over the summer with new rotors and pads from Pep Boys. Rotors are pro-stop which was the only ones they carried and I bought the best quality brake pads they had.
I have a 1 year warranty on the rotors and lifetime warranty on the pads… Well with only 6,000 miles these rotors are toast… Truck shakes like crazy when hitting the brakes slowing down. Slower than 20mph the truck doesn’t shake.
Long story short, I am going to try and get them warrantied and upgrade the parts to something else.
What kind of brake rotors do you guys recommend? I am not going to waste my time putting the same junk back on there.
Truck is a 2000 4x4 Excursion and I plan on towing a 10,000lb travel trailer next summer.
Thanks,
Termite is offline
post #2 of 13 Old 03-17-2011, 11:41 PM
i get mine from brake labs on ebay, sloted and drilled, with ceramic pads, $300 out the door, they wont warp, really good product, i use him for all my brakes now, warranty too
matter is offline
post #3 of 13 Old 03-18-2011, 06:59 AM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
I doubt they're really warped though.....
In fact, double-sided finned rotors are almost impossible to actually Warp.
More likely what's happened has to do with the braking surface of the rotor. It's got material stuck to it that grips & slips unevenly giving you that "warped" feeling by shaking & pulsating as the pads put pressure on that inconsistent surface.
If PepBoys won't replace them I'd bet if you took some 80 grit paper and a DA and gave both sides a good going-over to renew the surfaces you'd get your smooth braking back
NoRalPh is offline
post #4 of 13 Old 03-18-2011, 11:49 AM
take a look at your rotors, you might be able to see heat spots, kinda looks like a dart board, that will also give you a vibration felling when braking, i've seen this on my neighbors excursion, and my f-350, seems that the oem rotors cant take the heat of these big boys, switch to drilled and sloted ones, you'll be a happy camper
matter is offline
post #5 of 13 Old 03-25-2011, 07:08 PM Thread Starter
Well I talked to the boys at pepboys and their 1 year warranty was an absolute joke... Come to find out it was a 1 year warranty on manufacuters defects which really isn't a warranty at all. I will take the advise on sanding the rotors a little and see what happens. Thanks NoRalPh I don't have nothing to loose. It just really ticks me off after spending $250 bucks for a brake job and 6,000 miles later I have to do this. I would of rather spent an extra $150 bucks ($400 total) and not touch them for 50,000 miles. The cheap rotors are not saving me any money. I am only mad at myself for not being educated enough to know that I should of asked questions about the higher quality more expensive parts.
Live and learn. Thanks for the feedback guys.
Termite is offline
post #6 of 13 Old 03-25-2011, 07:30 PM
Here's a question,how do you wash your truck when it's cold outside?
Cold weather can have an effect in some cases.
icysmooth is offline
post #7 of 13 Old 03-25-2011, 07:34 PM
Bad Night's Avatar
Quoted: 3 Post(s)
I only run Ford rotors and pads . Never had one issue .
07 F-250 Outlaw , Rough Country 6 inch lift , 37-13.5 R20 Nitto Mud Grapplers , MBRP 5" Exhaust , 08 Mirrors , S&B intake , 5% Tint sides and back , 35% windshield .
Bad Night is offline
post #8 of 13 Old 03-25-2011, 07:50 PM
Powerstroke Techie
forddieseldoctor's Avatar
Double sided rotors warp all the time. However once they warp they end up wearing a thickness variation into the face of the rotor and this is what you actually feel during braking. The pad wears on the high spots, skipping over the low spots and works on wearing the high points down making it thinner in certain spots.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #9 of 13 Old 03-25-2011, 08:01 PM
Pep boys sucks.
2004 F-250, ZF-6, 03 turbo 4" mbrp exh. PHP reprogrammed FICM, sct X3, egr delete, auto meter ultra lite boost & pyro, arp head studs, firestone destination m/t's. ccv mod, mag hytec diff covers, 35% tint, dieselsite coolant filter, cat elc, B&W gooseneck hitch.
screamin7.3 is offline
post #10 of 13 Old 03-25-2011, 10:56 PM
sixgunsam's Avatar
Mine are warped every 6 months or so Put a straight edge on them and you will see.
This topic came up a year or so back and a couple of guys do what I have to do (which is no big deal to me) AutoZone has a 3 year warranty on their rotors and lifetime on the pads. I have had my truck for 6 yrs and have bought a set of rotors twice. Now I do exchange my rotors atleast twice a year, but I don't mind doing the brakes. The hardest and most time consuming part is jacking the truck up and removing the tires.
I do have 20" wheels and 37" tires along with towing a 14' landscape trailer with no brakes behind my truck every day, so that is obviously pushing my rotors past their limit, but as long as I am not throwing away money everytime I do it, I'm cool with it.
2000 F-250, CC Long Bed, DP Tuner, DIY Intake, Muffler Delete, Foil Delete, 6" Lift, 20" Incubus, 37" Toyo A/T's, 6.0 trans cooler, Billet converter, BD Pan, more to come..............................................
sixgunsam is offline
