What is normal "warm" starting time - Ford Powerstroke Diesel Forum
Old 03-17-2011, 10:26 AM
I have just had my new (to me) powerstroke for over a week now. It is a 01 model.
Facts...
Replaced both of the batteries when I got it because 1 of them tested bad.
My GPR is not functioning, will be replacing it this weekend.
Now my question, any time i crank the engine whether hot (just drove 20 miles to work) or cool (40 degree morning after sitting all night), it takes about 3-5 seconds to crank. The voltage meeter in the dash will drop to around 9 volts while cranking. I put an amp clamp on the (+) lead leaving the 2nd battery and it peaks at about 20 amps when warm, then slowly drops back to about 0-2 after the truck starts (takes about a minute to go back to 0-2). With my gasser I was used to about a 1 second start.
So my question, is this starting time normal? I thought maybe the starter is weak, but it is not pulling an accessive amount of amperage. I know the glow plugs not functioning will cause crank time to be longer if it is cool, but should not affect when the engine is hot.
Thanks in advance,
Brad
Old 03-17-2011, 11:00 AM
Sounds normal, especially if your GPR is out.
Old 03-17-2011, 11:08 AM
Feedback Score: 7 reviews
Send a message via AIM to dereku
heck without glow plugs mine doesnt even start ifs its really cold. less than 20.
Old 03-17-2011, 11:18 AM
Mitch
When mine is warm, it sometimes starts within 1 second but never more than 2 seconds. When it is colder it could take 2-3 seconds to start, but I don't have the stock starter in it. The previous owner installed a new one and I am not sure if the higher power one was installed. It turns over pretty quick.
Old 03-17-2011, 11:26 AM
Have to remember that there isn't a magical spark that gets the engine going. So it might take a few revolutions to get the compression and heat that is required to start.
Old 03-17-2011, 12:02 PM
The Tamed Racing Driver
It peaks around 20 amps????? Something isn't right, I assume with the amp clamp, because their is no way your starter will only pull 20 amps and still turn over and start. Need somewhere around 200-600 amps.
Old 03-17-2011, 12:04 PM
Almostdunfukinwidit
It probably isnt an autoranging VOM.
Old 03-17-2011, 12:21 PM
it was a fluke rms ampmeter
Old 03-17-2011, 12:22 PM
BTW... took it to an advance or az (can't remember which it was). and they read 0 amps on the starter draw and 0 amps on alt output, which is bogus.
Old 03-25-2011, 07:08 PM
just a thought...
Hi, I was just visiting here, but just a couple of things on using the clamp meter to check amperage. The clamp has to have a "dc amps" position on the switch (many clamp meters by fluke are "ac" amps only until u get into the really expensive ones.) Also, the clamp is directional (only reads in one direction) u may have known all this already, but it might help someone else. Thks, Eddie
