Yet another gauge thread... HPO mainly - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-16-2011, 10:57 PM Thread Starter
Buffalo444's Avatar
Ok, I'm gonna do gauges when I get my F-650 dash from RDP (3 gauge, 3 switch) quad a-pillar pod, and a column pod. So I'm thinking Boost 0-60, Trans temp 100-280*, pyro 0-1600*, Fuel pressure 0-100, Oil temp 140-320, coolant temp 140-320, and 2 HPO gauges 0-4000. The reason I'm thinking I should get 2 HPO gauges is they screw into the dummy plugs don't they? (in the HPO rails) That way I'd have a consistant reading of each rail. If they dont I guess im just missing the point
Jason
First rig: e99 F250 CCSB 4x4 auto, white, 388k miles: traded in
Then: 02 F350 RCLB SRW 4x4 zf6, silver, 201k miles, THREW A ROD
: traded to Jake
Now: 96 F350 CCLB DRW 4x2 auto, red and silver/grey, 266k miles: rusty but trusty
Buffalo444 is offline
post #2 of 6 Old 03-16-2011, 11:02 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
forget the hpo gauge. get a scan gauge and use the pcm readings.
ok this thread is been fullfilled and now can be closed
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #3 of 6 Old 03-17-2011, 01:09 AM Thread Starter
Buffalo444's Avatar
but the pcm only reads HPO in one rail... if im leaking from the other how would i know?
Jason
: traded to Jake
post #4 of 6 Old 03-17-2011, 02:21 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
it would off set it some how.
but imo its overkill. unless you are running some wicked injectors with a wicked hpop and wicked tunes on top of that.
Sold
LSP Group Threads
Jarrod B is offline
post #5 of 6 Old 03-17-2011, 02:32 AM Thread Starter
Buffalo444's Avatar
supporting mods first, Jarrod unless I get that 466 in there.... or a 530..... or a 570.......
Jason
: traded to Jake
post #6 of 6 Old 03-17-2011, 08:09 AM
Supporting Vendor
HPO gauges (the electric kind like ISSPRO and DiPricol) use the existing ICP sensor wiring using an adapter harness that simply plugs in between the sensor and factory harness connector.
It would be possible to get another ICP sensor and mount it in the passenger side head; you'd only need to supply the sensor with the 5v reference and signal return (ground) from the original sensor.
The connector can be purchased from your GM dealer (PT2319 or PT1825) and easily spliced into the factory harness.
Analog gauges are infinitely better than digital (just the way the brain interprets visual data). I have one in each of my 7.3L trucks. They're fun to watch.
I'm not a jerk, I just tell it like it is.
1995 SC/LB 4x4 PSD/Auto
2000 RC 2wd PSD/Auto
PHPDiesel is offline
