too much black smoke - Ford Powerstroke Diesel Forum
Old 03-16-2011, 04:30 PM
O.I.F. Combat Vet 11B
Ok guys I was wandering why I have sooooo much black smoke on mid acceleration. I know with my chip and split shot injectors I will have smoke but I am even getting some black smoke in my stock setting on the chip and not even under flooring it. I can be in daily setting and just give it part throttle and make quit a bit of smoke. Now I have no issues with blowing some coal under hard acceleration but all this smoke is getting out of control. The smoke does get easier to make in the hotter setting and in my street and race tune it is rediculous the amounts it puts on on stomping on the throttle. Any ideas?
Old 03-16-2011, 04:56 PM
hows your turbo and hoses? maybe a boost leak?
Old 03-16-2011, 05:05 PM
How much boost are you building, Im thinking a boost leak also.
Old 03-16-2011, 05:06 PM
stage 2's and stock turbo with a manual. Nothing you can do but upgrade your turbo. I have stage ones and I had the same problem with my manual.
Old 03-16-2011, 05:08 PM
Couldnt hurt to check, but thats a LOT of fuel.... especially with a manual. TW can really crank up the fuel without having to worry about blowing a tranny. Just my opinion
Old 03-16-2011, 05:13 PM
on the street and race no problem getting up to 25-26 pretty quick with lots of coal
Old 03-16-2011, 05:16 PM
I still think boost leak, with stage 2's you should definately be peggin that boost past 30 on the stock turbo
Old 03-16-2011, 05:17 PM
TW tunes is why your smoking. I had the same problem.
Old 03-16-2011, 05:18 PM
whats best way to check for boost leaks?
Old 03-17-2011, 04:02 AM
use a compressor and rig up a pvc cap with a gauge and compressor hose atatchment and pump up the intake tube to like 15 psi, and listen for leaks.
