valve cover breether..
what are most people doing with there breether so that the turbo isn't sucking in oil????
CCV mod......search and you will find more info than you want.
I am gonna just run it down to the bottom of the engine, and let it hang in the wind.... yea I know not much of a comic.
dump it, piece of hose, pretty simple, lol.
I have a ford valve cover breather and the ccv mod. I'm wondering if this is too much?
has anyone ever ran it into the exhaust ??
WHAT? Dude, don't do anything like that!
I don't know why you want to re engineer the CCV Mod but you can cause yourself some Big Problems with engine seals if you screw it up ![]() You either do it and dump the vapors to the atmosphere or into a catch-can and back into the intake without the oil. Make it yourself (but there's a right way to route that hose so it doesn't have a "low spot" to collect oil) OR buy the kit. |
well.. I have been mud racing for 10 years and we put out valve cover breathers into the upright heads... works great....
I was thinking of putting the breether into the exhaust down by rear of the cab.... Y wouldn't it work good??? |
I've heard of people dumping it to the exhaust but I would be concerned that the exhaust would cause too much back pressure not allowing the engine to vent properly.
![]() Are you Mud Racin' with a diesel? Because a diesel engine has about Double the compression ratio, it has about Double the blow-by. There is enough of this blow-by volume & pressure that it will push through every seal in the engine ![]() Again, no need to re engineer what the "Diesel Guys" have been doing for years
the exhaust would draw the pressure out of the breether hose... angled in tothe exhaust...
Just wondering.... if this would work wouldn't it be easier to deal with.. never draining anything, or smoke coming from odd places... |
