Contura rocker switch wiring help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-14-2011, 09:17 PM Thread Starter
Hello I just got done doing the f650 lower dash swap on my f250 with the contura rocker switches and I can't figure out how to make the switches illuminate, I have the switches setup as a selection device, all switches have power from steering wheel horn button, and depending on which switch is on, power is distributed between train horn, factory horn or siren, I have that all connected and working properly but the illumination doesn't work, there are 3 prongs on the bottom of the switch, on the empty prong do I run to power or ground? I wanted to make where the switch lights came on with my headlights, if any one could help I would greatly appreciate it, thanks
blake b is offline
post #2 of 2 Old 03-14-2011, 09:21 PM
CanuckF350's Avatar
Send a message via MSN to CanuckF350
Some one will chime in but if I remember correctly once grounded they will illuminate.
___________
Terry
08 F350 Superduty Lariat
Some mods!!
CanuckF350 is offline
