boost gauge- electric or mechanical
I am going to buy gauges for my truck but I was woundering if an electric boost gauge is any better than a mechanical and other than mechanical being cheaper what will be any advantages or disadvantages for either. Thanks
mechanical is simpler, reliable, and cheaper, stick with it.
makes sense, I guess with electric you would have to buy a sender for it also, thanks
I used mechanical, drill and tap the intake tube, super easy
Should come with a sender. but I'll take a mechanical any day. you can buy two or more mechanicals before you'd have the cost of an electrical.
I like my digital. Its easy to read and its exact.... no trying to figure out what my PSI is.
I'll take mechanical any day... trans gauge too... Boost gauge is not much diffrent than the oil pres. gauges/sending units on an old chevy from the 70's... the electric ones were unreliable as he!!, and the bulky sending unit on the back of the motor was a PITA to get to... Myself, I did not know you could even get an electronic boost gauge. The package deal I bought for my yellow truck had A piller pod, AutoMeter boost EGT and elec. trans gauges... trans gauge never worked, I got a mechanical one to replace it with, and been pleased as punch since... I waited over a year to call in a warrentee claim, and they told me sure, send it in. I never bothered, decided I never want an electronic trans gauge anyway.
Either one is fine, I have an electric boost gauge in my Camaro SS (turbo car) (also an electrical trans temp and electric fuel pressure in the car too) It just comes with a little 3 bar map sensor that you plumb into the intake. The one thing I like about electric is that you just have to run the wires inside the car, no chance of "kinking" a boost line running all through your engine bay and into the cab like a mechanical....
That being said, I have a mechanical boost gauge in my truck! And it works just fine as well! |
