Not a problem, just a WatIzIt? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-14-2011, 01:17 PM Thread Starter
My new to me 2003 7.3l F350 has four wires that are just snipped, and come out of the wiring loom right above the master brake cylinder. They are black, blue, red, and white (or faded yellow?). I thought something had been removed, but when I look at the other trucks in our work fleet, they have them too. What were they for? I wonder why Ford would just snip them, rather than terminate them or insulate the ends in some way.
Whilst I am at it, in the glove compartment is another watizit. It is a round electrical plug, that probably could hold 8 wires. There is only one wire in it, that joins two of the pins. There are no other wires or pins in it at all. Watsdatfor?
Thank you,
Bob
Bobbert is offline
post #2 of 6 Old 03-14-2011, 01:20 PM
4ds4me's Avatar
Wires above the mater cylinder are extras or upfitters the other end are under the panel below the steering wheel on the right side, as for the other in the glove box IDK.
Greg, USAF Retired
2001 F250 Crew Cab, Long bed, 4X4 PSD
4ds4me is offline
post #3 of 6 Old 03-14-2011, 01:32 PM
Retired Coastie
Not sure if this is what you see, but a brake control normally has white, blue, red and black wires. Check under the dash and see if the plug is still connected. Maybe someone just cut the wires under the hood.
MikeThompson is offline
post #4 of 6 Old 03-14-2011, 01:35 PM
Feedback Score: 5 reviews
Mine has them as well...but everything works (except the back-up sensors) so whatever, lol!
ToMang07 is offline
post #5 of 6 Old 03-14-2011, 01:38 PM
Smoke Eater
Send a message via Yahoo to fdchief
these were actually left there from the factory.. they are there if you wanna hook them up to something and not run wire thru the firewall. if you pop off your fuse panel under the steerin wheel you will see the other end of them stuffed up in there.
2007 F-250 Lariat Crew Cab
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
SCT Livewire w/ Tony Wildman Tunes
PMM Full EGR Delete/ Coolant Kit
Hornblasters 540 Kit
LED Lightiing All Around
All kinds of other Goodies!
2005 Lariat Crew- GONE!
2011 Lariat Ultimate Crew- GONE!!!
Back in a 6.0hhhhh and lovin it!
fdchief is offline
post #6 of 6 Old 03-14-2011, 02:03 PM Thread Starter
So thats what they are....
...thank you, thank you, and thank you..... (grumble grumble....now why didnt ford just label em as such.....)
Bobbert is offline
