EGT fitting - Ford Powerstroke Diesel Forum
Old 03-11-2011, 08:10 AM
EGT fitting
Some how i lost the tap style fitting for my egt gauge.I have my probe hooked up after the turbo but im about to install a new mbrp exhaust but i want to my probe to before turbo.I have a brass 1/4 compresion with 3/8 npt and the center has been drilled out to 1/4 already.My question is,is it ok to use brass since it melts at 1700*F and i want to mount it on the drivers side manny.
Old 03-11-2011, 11:45 AM
Feedback Score: 5 reviews
I would not use brass...chances are it won't get that hot.... (Over 1300 will kill it) but you never know.
The EGT probe really should be on the manifold.... its really not that hard to install, and you'll get a better reading. I can send pics if you want, in the mean time here is a link... (let me find it...)
Old 03-11-2011, 11:48 AM
Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke
The Diesel Garage - A Performance Diesel Site
Old 03-11-2011, 01:24 PM
The 2ed url u posted showed a brass fitting and that showed the place i want to put it
Old 03-11-2011, 01:28 PM
Lol, I never said you couldn't... I just said I wouldnt.... I don't think it's a good idea to mix 2 different metals like that... they expand at different rates anc could cause it to loosen or whatnot.
Old 03-11-2011, 05:31 PM
On that note. I live in Michigan. I sent a truck to Florida in December for a cooling test. I pre-ported the exhaust which is stainless, and installed a copper 1/8 NPT pipe plug in it port thinking I could easily swap in a thermocouple when I arrived to do the testing. WRONG! From the salt and heat cycles in 1200 miles the plug broke off instantly when I tried to remove it. Granted copper is soft and could easily be drilled out but access is another thing. I would use similar metals.
Old 03-11-2011, 06:13 PM
^ hmmmm that's not good since copper has a higher melting point than brass
