Old 07-21-2007, 12:08 AM
dointime4alivin dointime4alivin is offline
ENGINE LIGHT?????
I recently purchased a 2002 F-350 Powerstroke (bone stock.) I have added a S&B cold air intake a Diablo Sport Tuner (using economy tune) and I cut the muffler off. Now when I gas on it hard the engine light comes on. Anybody had this problem or does anyone have a solution. The Diablo realy made a difference in power.
Old 07-21-2007, 12:16 AM
2005F250 2005F250 is offline
Its a low fuel pressure CEL. My dads 7.3 is alway setting it off (his fault). Its not a big deal just plug in and clear the code. If you don't hold it out till 4th the light will stay off.
Old 07-21-2007, 04:53 AM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
It sounds to me like you are over boosting the engine. What is happening is your getting up around 25 psi and the map sensor is reading this. Easy correction to stop this. Add a map fooler to your mods and this will stop.
Old 07-21-2007, 04:55 AM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
its more than likely the comon p1211 , alot of trucks do that under hard accel with chip installed nothing to worry about, its possible to be a overboost code , and a map fooler may take care of it , pull the code and se which it is giving and address the issue from that point
Old 07-21-2007, 05:30 AM
SgtStroked7.3 SgtStroked7.3 is offline
Send a message via Yahoo to SgtStroked7.3
I agree with the overboost solution, over 21 or 22 psi u will throw a code.. just get a map fooler, u can do it urself and pay >$10 or u can buy one and pay anywhere from $20-60. good luck!
Old 07-21-2007, 05:46 AM
the bad part about mine and that map fooler , i bought one from dfuser and the cel still comes on , not sure if thats the greatest thing or what
Old 07-21-2007, 05:55 AM
jackgf250hdsd jackgf250hdsd is offline
Send a message via MSN to jackgf250hdsd
get a hold of diablo sport and the will send u a custom tune, they did that for me and truck run's great.
Old 07-21-2007, 05:56 AM
The below is copied and pasted from one of my threads about DIY map fooler.
I still need to fab a mounting plate and take the pictures and post them up in a complete detailed write up on this. I think I will do that today when I get off work.
Ok so I couldn't wait till tomorrow so I took the regulator off my air compressor to test it out. I guess I either got the wrong thing or a faulty regulator because this time it worked.
So don't worry I am going to put my regulator back on my air compressor actually I am going to buy a good regulator for that one with a filter and oiling system.
So tomorrow I will take pictures if weather permits.
But for now what I used was an Air Pressure regulator, you can get a 160 psi one for 7 bucks at Harbor frieght link below.
Then I used 2 barb hose connectors 1/4 NPT (national pipe thread) one on each side I cut the map line going from the turbo to the map sensor. I put a hose clamp on eachside and attached the hose. Make sure you have the flow arrow pointing towards the map sensor. Also make sure you set the regulator to 20psi prior to installation the easiest way to do this is to use an air compressor. Then I zip tied it to the cac tube coming off the intercooler going to the intake. I plan on making a mounting plate this weekend for it.
Then your pretty much done. Take it for a test drive and build up your boost and watch your dash if you look for a check engine light you won't find one because it won't come on.
All and all it took me about 15 minutes to install this.
Pictures tomorrow.
Parts list
Harbor Freight Tools - Quality Tools at the Lowest Prices
House of Tools -Hose Barb With Male End qty needed 2
and 2 hose clamps that will tighten down onto the hose. I don't know what size you actually need I used 3/8 hose clamps.
The links are just to show you what you will need they are not suggestions on that is what you should purchase or who to purchase from. I just used them as reference.
I will get you some pictures tomorrow.
Old 07-21-2007, 06:47 AM
Southpaw Southpaw is offline
1/20/2013
Mine does the same thing. It's throws a low fuel pressure code. But I can turn truck off, and back on again, CEL is off.
Also, driving like normal for about 10 mins after light comes on, it will go off. It still leaves a code to clear, even after light goes off though.
Mine only happens on real fast 0-80 accelerations.
chris
Old 07-21-2007, 10:28 AM
The codes I got are.
P0603 Internal Control Module KAM Error
PO541 Manifold Intake Air Heater
What does that mean
