sway bar bushings???
do they just pull off or what and where can i buy them?
I just did mine a week ago. I got mine from the local parts store for $21.90. Be careful because for some reason there is two different sizes listed. They gave me the ones that were way two small first. Very easy to install. Two bolts on each one, the bracket pulls off and there is a split in the bushing pulls right off. I used an impact gun and a jack. I used the jack to hold the sway bar in place. Very easy and solved my clunking sound!
ok thank you sir
The bushings need to be pressed out. I used a ball joint press on mine (looks like a big c clamp).
i believe its only 2wd that needs to be pressed i did my bushings and stabilizer links last week you just need a 15mm wrench 18mm socket for the links and i think the bushing were held in by 4 13 mm thats for a 4wd
energy suspension seems to be one of the best. theyll tell you what u need on their website.
you only need to press the old out if you use energy poly stuff and re-use your old links. if you replace the whole link then its just the two bolts and then chuck the old one. I didn't want to use new china made cheap stuff so I used the energy poly and it was not fun but not hard either!
they wanted to give me the 90 dollar links i could not buy the stuff you all got
when you say clunking what do you mean? i have a feel/noise in my back end, when i give it throttle it feels like it moves then stops at a certian point, ... its not a diff feeling ive had that looked at, same with ujoints and such
i had to press my old bushings out then replaced with the energy susp. ones. |
