Changed water pump, quick antifreeze question - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-09-2011, 06:09 AM Thread Starter
Semper Fi, Devil Dogs!
usmc_butler's Avatar
Question Changed water pump, quick antifreeze question
I changed the water pump out on my 7.3 last night and need to buy antifreeze today. My question is how may gallons do I need to get and what type of antifreeze would be the best?
2000 Crew Cab DRW 4x4 Lariat
Rollin on 22.5's 255/70/22.5
Blacked out
Wicked Wheel
Foil Delete
DIY intake Mod
4" Straight piped
HID Headlights
"I'm as confused as a baby in a topless bar!"
usmc_butler is offline
post #2 of 6 Old 03-09-2011, 06:14 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
well what was in it? green?
im a moto vc5 green antifreeze person. 3 or 4 gal of concentrate should work. pre mix is x2 that.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #3 of 6 Old 03-09-2011, 06:16 AM Thread Starter
Green is what was in it... But I don't know the rating of the antifreeze that was in it
Blacked out
Wicked Wheel
Foil Delete
DIY intake Mod
4" Straight piped
HID Headlights
post #4 of 6 Old 03-09-2011, 09:39 AM
I'd grab some CAT rated EC1 ELC coolant, concentrate is definitely best.
Dietoremain is offline
post #5 of 6 Old 03-10-2011, 10:55 AM
There will be all kinds of advice on what you could or should replace your coolant with. The important thing to remember is that you aren't doing a flush/change to new coolant you are just topping up. The fancy upgraded coolants such as CAT ELC aren't compatible with plain jane green.
If your weather is warm enough and you have no idea what is currently in the block then I would just top off with water and then look at doing a full flush to a new fancy coolant such as the CAT ELC as soon as you can.
2000 F350 4wd CC SB PSD
Normal mods plus gauges and PHP chip
Lowered to F250 height
Stock tire size, looks stock.
18' 10k# equipment trailer
30' Travel Trailer 7500#
Kioti CK30 tractor
Kawasaki KLX250s Dual Sport
Highbeam is offline
post #6 of 6 Old 03-10-2011, 11:20 AM Thread Starter
Thanks everyone for the good advice! Im just gonna go with Highbeam's suggestion and run distilled water until I have time in the next few weeks to do a full flush...
Blacked out
Wicked Wheel
Foil Delete
DIY intake Mod
4" Straight piped
HID Headlights
