2000 7.3 runs colder than normal after 6637 mod - Ford Powerstroke Diesel Forum
Old 03-07-2011, 05:14 PM
This has probably been addressed before, but i have a question. I recently did the foil delete and the 6637 mod on my 2000 F250 7.3 and now my temp gauge on the dash..the factory one...reads barley above cold. any ideas? is this normal? I havent installed any gauges yet due to the fact that they are freakin outrages, i know they are important but on a budget, so all im seeing is the factory installed coolant temp. any help would be appreciated
thanks
Old 03-07-2011, 05:31 PM
Was it like that before the mod? sounds more like a thermostat problem not intake related
Old 03-07-2011, 06:12 PM
ya the intake and the foil delete shouldnt effect the running temps of the truck, maybe your thermostat is stuck open? or maybe you temp sensor is going out? the factory guages are more/less dummy lights..
Old 03-07-2011, 06:15 PM
CSP Resident Spooby
You can get a set of Glowshift gauges (like Pyro, tranny and boost) with the matching pod for your truck for $200 shipped... just throwin it out there. That's what I have on my truck and they work great.
Old 03-07-2011, 06:40 PM
i did change my serp belt as well when i did the rest, which involved removing the top radiator hose....an engineering marvel....should have changed thermo whille i had it apart. ill check the temp sensor.
Old 03-07-2011, 06:44 PM
i did check the glowshift site, very affordable. ive been looking for someone selling used or extra. i usually have 2 of everything and i have found that most rednecks like myself do too lol
Old 03-07-2011, 06:46 PM
CSP Resident Spooby
That's why I bought 'em. I'm a full-time college student also working full-time, so I gotta be cheap! lol
Old 03-07-2011, 08:05 PM
so is the 203 degree thermo an item my local parts store would have or is it a special order item?
Old 03-07-2011, 08:08 PM
why not just go with the glowshift 3 in 1 gauge like this: GlowShift 3 in 1 Combo Gauge - Boost, Exhaust Temp, Temp Readings
-Raul
Old 03-07-2011, 08:13 PM
I havent sen that one. Thats cheaper than most single gauges!!! thanks for the tip!! Does it come complete with all the hardware, wires, probes,....etc?
