Gauges installed....boost #'s ?
Finally had a chance to install my Isspro gauges from Dieselmanor. Very well put together kit. Will post pics later, but for now I have this for you guys:
![]() This wasnt quite max boost, I hit just about 24 lbs. How does this compare to you other guys with stock turbos and sticks?? Mods I have are a Superchips 1705, AFE stage II, 4" magnaflow, ITP boost fooler. |
I can hit 25 PSI with my yellow truck... mostly stock, DIY intake, straight pipe, unhooked wastegate, DP tuner on 80 econo... did gauges first in that truck, max of 17 PSI before I disconnected the wastegate... then got about 19 PSI, DP tuner made the biggest diffrence...
I can hit 28-29. DIY intake, unplugged wastegate, Hypertech on 100hp, walker BTM
by unplugged wastegate do you guys mean disconnect the red hose? or physically disconnect the lever arm?
ALSO, i would'nt recommend running it like this for a long period of time unless you have upgraded to a Wicked Wheel or have the ATS Ported Shroud Housing. My turbo housing will be here tomorrow Last edited by hvprohop23; 03-06-2011 at 08:55 PM. |
i dont have a boost fooler(PHP fu on the way too!) but with the superchips 1705 i hit 25 all day long no probs. thats about right.
