Old 07-20-2007, 09:11 AM
99POWERSTROKE7.3 99POWERSTROKE7.3 is offline
how do you pull
Hey i have a 99.5 ford super duty with 7.3 power stroke in it. I was thinking about going to a sled pull. I have the stock auto transmission the 4r100. I know to put it in 4 low and then what. Do you put the shifter into 1st then shift to second and leave it in second or shift it into drive which would be 3rd. if you keep it in second do you leave it in second till the sled stops or do you shift it back down into first when you start to slow down becuase of the wieght. and what do i sett my chip at 60 tow 80 or 120 thanks.
Old 07-20-2007, 09:22 AM
CSIPSD CSIPSD is offline
I pull in 4 low in Drive with the OD locked out... Highest setting I have and let her fly!!! Pulling it 10 times more fun then drags...
Old 07-20-2007, 10:26 AM
dieselpower99 dieselpower99 is offline
yeah no **** more power is better just add weight if you can
Old 07-20-2007, 11:10 AM
onecrazyblackredenck onecrazyblackredenck is offline
pulling will you mess up your truck? I am wanting to get into this but I am scared of tearing something up. 4lo **** that sounds scarey. I guess you just have to know when to let out of it huh
Old 07-20-2007, 11:24 AM
Weight to the front, not the back, you want to loose as much weight from the back as you can...
Old 07-20-2007, 11:27 AM
Once she starts hoppin bad then lift, if not then keep her wound up until the sled stops moving...
Old 07-20-2007, 11:50 AM
Lord Tauk Lord Tauk is offline
Send a message via ICQ to Lord Tauk Send a message via AIM to Lord Tauk
You can mess something up going WOT down the highway.
I guess pulling could really accelerate breaking something vs. never pulling?
