  #11 (permalink)
Old 07-27-2007, 06:01 PM
BadAss01F250 BadAss01F250 is offline
Originally Posted by lilredpowerstroke View Post
You don't have a chip or programmer and you still went over 100 mph. I don't believe it. The factory speed limiter is set at 94. When you hit the limiter it doesn't do like gas engines where it starts and stops. On our engines the computer gives just enough fuel to hold it at 94. So without something to turn the limiter off how can you go over 94????
THATS DEFINATELY TRUE, UR SPEEDO MUST BE OFF... IVE GOT A PIC OF MY SPEEDO TOPPED OUT BEFORE MY TS CHIP, IT SITS AT RIGHT ABOUT 94 (AND I KEPT IN IT FOR AT LEAST 5-10 SECONDS AND IT WOULDNT GO FASTER THAN THAT)...NOW WITH THE TS CHIP ON 140+, I CAN WRAP IT PAST 100
  #12 (permalink)
Old 07-27-2007, 07:04 PM
najaf4life najaf4life is offline
Look Ma.. No Hands
Originally Posted by TwinTurboStroker View Post
He could have bigger tires on it, maybe....
if you have bigger tires it makes the speedo say that you are going slower than what you really are..... around two or three weeks ago when I was racing a dmax he pulled over and we talked I asked him how fast he was going cause I knew that mine I was off and he said that he had it pegged at 120..... and mine only said around 90 or so.... and I couldn't go anymore..... and the only time he passed me was once I couldn't go anymore and that is when he said he passed me when he was going a 120 and he barely passed me then.....
  #13 (permalink)
Old 07-27-2007, 10:15 PM
lilredpowerstroke lilredpowerstroke is offline
Originally Posted by cblackb View Post
Well, all I know is that I'm running stock sized tires and I've had my truck up to and over 100 a few times. In fact yesterday when this happened it hit 100 and certainly was still pulling hard and finally after about 5 seconds or so it hit the ceiling. I'm fairly certain that I've got a stock computer HOWEVER, the previous owner must have done something because there is a big sticker on my computer box that says "Diablosport" and picture of a Devil. I'm pretty sure it's stock though (or the existing chip is in stock mode?) cause I can't make smoke no matter how much I try. I've been meaning to pull it out sometime and look at it I just never have gotten around to it.
I would almost bet you that you have a 60 horsepower chip or around there. My 99 wont smoke with DJ's tow tunes either. If it was my truck I would pull the PCM and check for myself.
  #14 (permalink)
Old 08-01-2007, 04:57 AM
cblackb cblackb is offline
You're probably right actually. I have a small chip in there and don't even know it. All I do know is that I have stock tires and I checked the speedometer vs my wifes new car, she tailed me at 65 and my speedo is correct. I MUST have a chip, I've got to knowing now that it's not supposed to go over 94.
  #15 (permalink)
Old 08-01-2007, 05:14 AM
rankroddin250 rankroddin250 is offline
we had a f450 dualie with a utilitie bed/welder/air compressor/ cutting torch / a billion tools on our work truck here at the railroad... if you wadded it trying to get up an go it would do that 3-5 times before it would ever get out of first gear it was retarded!!!!!! that was the only 6.0 i have ever driven and my opinion on them was they where a slow POS! untill i found this site
oops didnt see your was a 7.3 I duno sounds liek the same thing tho <edit>
  #16 (permalink)
Ditty Ditty is offline
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
Most speedo's aren't 100% accurate after 80-ish mph...so I'm guessing it's your speedo. I COULD have been a mild tuner, but I"m not certain. I know in my Neon, when I got it up to 120+ on the speedo (Stops at 120), I was only doing about 115-ish. (Got clocked by a COP in the AZ desert and NO ticket. He was confused on how a 1998 Stock-looking Neon got up that fast!!! LOL )
