Newbie question on 4X4 - Need advice. - Ford Powerstroke Diesel Forum
Old 03-05-2011, 10:40 PM
Hi all-
Sorry for the lame question on my first post, but I'm making the move from a gasser to a 7.3. I'm looking at two trucks right now. One is an 01 F250 with Auto 4x4 (knob on dash), and the other is an 01 F350 with the 4X4 shifter on the floor. Wondering what's the difference and why I might want one over the other? Can both be engaged while moving?
I'm sure I could search for this while I'm in here, but I'll call it a bonus question....What's the difference between an F250/F350 anyway. They look like the exact same truck, but 3/4 ton versus 1 ton. Is that just basically payload capacity?
Any other advice you'd like to offer up / things to look for while shopping would be appreciated as this will be my first diesel, so it's all new to me.
Thanks!
Joe
Old 03-06-2011, 06:24 AM
There's not much difference in the Man-vs-Auto 4WD other than Simplicity -vs- Convenience.
With the Auto system you can drive with the Ft. hubs Unlocked and with the twist of the dial the TC engages and the hubs lock themselves (at least that's the way it's supposed to work ) BUT things being the way they are, it also means you have a system with more things to FAIL and actually Keep you from getting 4WD when you need it!
BOTH with engage while moving as long as your manual hubs are already Locked.
The 250 -vs -350 is just the driveline & suspension for the extra weight. All things being equal, I feel more is better and would give a 350 a bit of an advantage 'cause "ya never know..."
There was a "What to look for when buying thread" I thought, but I don't seem to find it right now....
FOUND IT! -> What to look for when buying a USED 99-03 PSD (I was only looking at the Stickies...)
Old 03-06-2011, 04:01 PM
After 8 hours of driving today, I was able to check out both trucks. The 350 is out. That guy has had a very hard life. However, the 250 is a winner. Body is nearly perfect, save for one little spot of surface rust on the bottom corner of a door. Interior is perfect as far as I can see. Bed has no 5th wheel ball and is almost scratch free. Tranny fluid was nice and pink. Only alarm was the K and N sticker on the airbox, although there was no K and N filter in it. I did take off the intake hose and the turbocharger fins didn't look rounded off or anything and were tight against the housing. Almost no oil blowby in the intake. The fins were a little discolored on the edges though. Is that normal? According to the dealer its a one owner local trade.
I wasn't blown away by the acceleration power. I currently drive a Nissan Armada with the 5.4 and it has more pop. Maybe I'll notice it with the diesel when towing?
In any event, the truck has 120K, is a 2001 F250 XLT Crew with the normal power options. Based on what I describe, would you pay 14,500 for this truck?
Opinions welcome, good or bad! Thank you!
Old 03-07-2011, 06:18 AM
I wouldn't worry about "colored" fins in the turbo..
Don't worry about acceleration either, stock the 7.3 isn't really "peppy" but, will you will notice is that while towing, the acceleration won't change, it'll pull the same with or without the trailer
$14.5 sounds a bit pricey,,,, look around for comparable sales and see if you can negotiate a better deal. If you're buying it from a Ford dealership though you have to figure on paying more because of, hopefully, a better warranty.
