| View Poll Results: Where'd you put your Pyro Sensor? | |||
| In the Exhaust Manifold. |
26 | 96.30% |
| In the Turbo Down-Pipe. |
1 | 3.70% |
| Voters: 27. You may not vote on this poll | |||
I bought it with it in the down pipe, I read that it was a good spot so I left it! I do plan on ordering a new 4" system so I can move it then, where should it be?
Never mind, mine is on the left side, the up pipe. Last edited by chrispaine; 03-06-2011 at 05:37 AM. |
Exhaust manifold. I am more concerned with the temps going in than coming out.
Well, what really matters is where it SHOULD it be to allow you to protect your
engine... Hint: Down pipe is NOT the answer |
Manifold for more accurate temp readings... putting it in the down pipe is like going to the eye doctor, and asking for glasses that are almost good enough for you to read clearly, but not what you really need...
manifold/up pipe(where mine is) I've driven a truck with the pyro in the DP it was completely useless, the gauge never went above 600, aka it was really like 800-900 at least. you can never tell. uselessss!
In the driver's side manifold before the up pipe.
In the manifold. As stated above, you want to monitor the temps going in the turbo, not coming out.
I have both of mine in the manifolds.
I wasn't thinking, mine is on the left.. The up-pipe, I need to change my vote ha. It's in the lower part of the up pipe, should it be moved up to the manifold?
