Ok, I want to make sure I'm clear on this...
I have the Glowshift Gauges with the "Drill/tap" style connector, (NOT the "T" fitting) and want to be sure of this info... In this write up, it says to drill/tap here for the Boost sensor: 3-Gauge Install Pictures ![]() How the heck do you get the shavings out? Do I have to disconnect everything and take it all apart just to tap this? I understand the Exhaust probe is drilled upside-down and then vaccumed out to be safe.... but how the heck is this supposed to work???
not sure about the 7.3 but on my 6.0 i took the whole intake off to be sure there were NO shavings .
I don't know about turbos, but I had a delicate situation with hydraulics that need to be tapped. I used grease (axle grease I think) on the tap and in the tap flutes, did a few turns, pulled out the tap, cleaned it, re greased it and repeated until I was done. I did the same thing with the bit to drill the hole, but it was a brand new cobalt bit (rigid brand from home depot) and used low gear at slow RPMs on the drill. I did this AFTER the fluid filter (so the filter would not have caught the shavings) its been 2 1/2 years and no seal problems. I normally don't do stuff like that, (normally I would undo everything remove the hydraulic cylinder,etc.) but I was on the spot in the middle of a job. don't know ho well it would work in your situation but its an idea. Good luck.
Pull the inter-cooler tube off then stuff a rag in there past where the hole is drilled. After you drill & tap hole vaccum the shavings out then pull the rag out. You'll probably have to pull the IAH element out of the intake also. I'd say screw all that & put a T in the MAP line, that's where I put mine.
Yeah... well... I dont have the sensor or other stuff for the "T" line... its a digital gauge. |
Why not just delete the AIH and use a plug tapped for your sensor?
Yeah, what he said... That's what I did to my yellow truck... bought a plug to fit the hole (it's metric, 22mm I think, almost 1/2" NPT) and tapped the plug for the 1/8" NPT boost line fitting... worked great for me, and got rid of the AIH...
What sensor? All you need is the T with the 1/8" comp fitting, it's the same reading in the MAP line as you would get tapping the spider.
Do you have to remove the whole thing? Any write-ups how to do it? |
It's simple, unhook the wires, tape them up, remove the AIH, install plug. A 1/2" NPT plug can be used, but the threads are slightly off, and you bugger up the threads to where the AIH might not work again... I chose to get a plug with the proper threads, and drill/tap it to the 1/8" NPT fitting... basicly becomes a large reducing bushing, from 1/8"NPT to 22mm.
Will have diffrent issues with my early '99 truck, no AIH to delete, only option will be a "tee" in the MAP line... |
