7.3 wont start - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-05-2011, 01:03 PM Thread Starter
7.3 wont start
Stoped and fueled up after fueling went to start. had no wait to start light. found blown fuse under hood replaced fuse wait to start light worked no start, was told bad gpr replaced it with a cheeper relay that should have worked. truck started and ran for about 3 hrs. parked truck and gpr kept heating the glow plugs. bought the correct relay started the first try but nothing since and now the wait to start light wont come on no bad fuses but a confused owner please help
boyter is offline
post #2 of 6 Old 03-05-2011, 01:23 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
That is usually an indication of the fuel heater in the fuel filter bowl shorting out. Unplug the heater, recheck that 30a fuse and see if the light comes on and sarts.
dhanna6powerstroke is offline
post #3 of 6 Old 03-05-2011, 09:10 PM Thread Starter
un pluged heater fuse still good still no light still no start i have power to gpr little red and little orange also have power but none to glow plugs
boyter is offline
post #4 of 6 Old 03-05-2011, 09:19 PM
Shaking the Bush Boss
CHUCK's Avatar
check the valve cover harness's....may have burnt the connectors up to the glow plugs
Chuck
CHUCK is offline
post #5 of 6 Old 03-07-2011, 05:33 PM Thread Starter
checked harness all is good there. pulled the mod out off the driverside kick panel smelt burnt. Removed all external screws took apart the mod is burnt inside any ideas as to why? a rebuilt one is 250 and would hate to put it in and burn it up also
boyter is offline
post #6 of 6 Old 03-07-2011, 06:26 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
IDMs do fail from time to time with no real reason. not the best place for a module if you ask me
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
