1st Service
Just bought myself a 01 F350 with 7.3. I have always done my own maintenance on my gas burners, so figured i would do the same with my new powerstroke. I researched on here an other places the process for changing oil and fuel filter (Welcome to guzzle's Ford PSD Maintenance Web Page).
Went to store bought 15 qts of motorcraft 15w40 oil, motorcraft oil filter, and motorcraft fuel filter. Now i realize after researching on here the choice of oil/filter manufacturers differ from person to person. I talked to the ford service dept and they recommend nothing but motorcraft, so I figure that is what I should use. Came home and got started. Drained oil, took off old filter, filled up new filter with oil and installed. replaced oil plug gasket and put plug back in. Added 15 qts of oil (note to self get a bigger funnel). Crank engine let it run a minute or two, turn off and check oil level. Only comes about 1/2 between add and full. I have done some reading on here and seems like some folks say add till you get full even if that means 16 qts. others say it holds 15 qts so put in 15 and leave it. well i just cannot stand the thought of running the truck unless the dipstick reads full so I am gonna be getting another jug of oil and adding till full. now for the fuel filter. Apparently the previous owner has not changed the filter in a long time, because the nuts holding the plastic "powerstroke" cover were so welded on that I broke them off (both of them). So now I have something else to repair Then i remove the fuel filter cover, no problem. go to drain the bowl and it won't, realize i should have drained before removing the cover so their would have been some pressure in the bowl to force the fuel out. So now i put the filter back in and cap back on getting fuel everywhere as i push the filter back in. open the drain valve turn the key to start the fuel pump up and it finally blows whatever had the drain tube stopped up out. take cap back off, open new filter and realize that someone has put on an aftermarket filter with the cap permanently fixed to the filter. Put old filter back in. Now, I need to order a new factory fuel filter cap and install the motorcraft filter.So it was an adventure, but i learned some stuff along the way. So it should be easier next time! |
Sounds about normal... Somethings that will help...
- Punch a hole in the bottom of the old filer after you make sure it will come loose and before the gasket separates from the base and starts leaking. That way the filter is empty as you take it off, way less mess. - slip a piece of fuel line over the fuel filter drain tube and secure it so when you drain the bowl you can catch the fuel and it wont drain all over the frame and make a dripping mess. Yea, wasps like building nests in the drain hose. - get an extra fuel filter and keep it behind the seat in case you get some bad fuel. - read the little book that came with the truck. Instruction for checking the oil say to let it sit for 10-mins before checking the level. I bet you will get that extra quart you were looking for. Also, your truck will have a oil level it likes. Mine will burn off that top quart if I try to keep it full. If I leave it in the middle of the full zone I may have to add a qt in 5000 miles. If I try to keep it full I can add over a gallon in the same milage. |
Get ready to be bent over when you replace the filter cap.
Last time I replaced the fuel filter was while my truck was in the shop getting new tires. Later, when I went to replace the filter myself I realized they had used one of those one piece aftermarket filter/caps. This meant I had to go to the Ford dealer and buy a new plastic filter cap. $75.00 + tax !!! I raised hell and asked why a @%&%#@# plastic cap worth about $17.00 cost close to a hundred dollars, more than the oil and filter combined. The parts manager didn't have an answer except something about it being made out of some high impact, space age polymer. I told him it wasn't going on the space shuttle, I just needed a plastic cap to keep my filter in. He asked if I was going to buy it and I said I didn't have a choice but it was bulls#it and a ripoff. rant over |
Or talk to this guy. Same guy with the maintenance page.
Replacement O-rings for Ford Diesel Engines Last edited by DND58; 03-06-2011 at 04:36 AM. |
A napa gold fuel filter comes with the cap onthe filter. It might be cheaper using a new one of these each time instead of buying a new cap.
thanks for the replies guys. I ordered the 15.00 cap from dieselorings.com.
previous owner never changed it and i broke the threads off also. went to dealer and it was i think $37 before tax....
The last WIX fuel filter I bought still had the integrated lid/filter. They are saying the part number supercedes the old non-integrated lid filter. I kept my lid just in case.
To the OP, as far as the oil level goes, wait a bit, like suggested above, to check the oil level. It takes some time for all the oil to get back to the pan. |
