  #11 (permalink)
Old 07-20-2007, 10:54 AM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
Originally Posted by vitalidle View Post
Actually BC the superduty's dont have an injector pump per saythe hpop is what fires the injectors but still if they are charging that much for a fuel pump thats rediculious
That is crazy for a pump you are correct. I thought our trucks had an injection pump that increases the fuel pressure for the injectors. Like the old chevys. Had a supply pump on the side of the engine and then a pump that increases the fuel pressure.
  #12 (permalink)
Old 07-20-2007, 10:58 AM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
No I don't think so the hpop takes engine oil and boosts the pressure to around 3000 psi give or take some and that is what fires the injectors hydraulically or the mechanical part of course there is the electrical part as well. As far as I know the 7.3's only have one fuel pump that feeds the fuel from the tank to the engine. I am wrong all the time so Im sure someone will chime in and give the correct info lol
  #13 (permalink)
Old 07-20-2007, 11:08 AM
Ok how about we get marc to do a write up on the fuel injection system. That would be sweet.
I don't know how it works. But I do know the the injectors are controlled by the IDM.
  #14 (permalink)
Old 07-20-2007, 11:10 AM
Im at work but when I get home tonight I have a good site that explains all that. Its from international I think I will link it up for ya when I get home. I won't be home till 10ish.
  #15 (permalink)
Old 01-23-2009, 12:39 PM
Princeofrogs Princeofrogs is offline
I had same problem
my solution?
(Crankshaft Control Sensor)
it never gave me any trouble after that
takes 5min. to put one in
