Old 07-17-2007, 08:19 PM
alfajay alfajay is offline
Too cold for AIH delete?
Located near Philly, PA with some travel to the midwest and occasionally to MI, is it too cold to do the AIH delete? Anytimes the temp drops below 30deg the truck gets plugged in. Any thoughts or opinions, thanks
Old 07-17-2007, 08:24 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
You can still do it as I have and Im in the U.P. of Michigan. Its there to heat the intake air for emmissions. It will smoke a bit more and longer till the truck is warmed up.
Old 07-17-2007, 09:20 PM
CSIPSD CSIPSD is offline
AIH has 0 to do with cold starts... its about extended idle... remove it and forget it.
Old 07-17-2007, 10:24 PM
ok, isn't there a mod that effects cold weather...ebpv? maybe a misread it, too much info on here lol
Old 07-18-2007, 12:53 AM
SgtStroked7.3 SgtStroked7.3 is offline
Send a message via Yahoo to SgtStroked7.3
ebpv aids in warming the engine faster yes
and for suggestions... Water/Methanol injection next
