A few questions from a diesel newbie!
Hello everyone.
About 2 weeks ago I purchased a used 2000 F250 PSD and have a few questions as I am new to the diesel world. I hopped on google and searched for some diesel forums and thankfully found this wealth of information here. The truck specs are: 2000 F250 7.3l PSD Crew Cab 4x4 141,500 miles Airraid intake Banks 4" exhaust 4" lift with 33" tires Other then that I believe everything is pretty stock. I need to do an oil change and really don't have the time to do it myself this week (I am going on a little trip next week) so I called a few places for prices and what oil they use. They all said they used "dello" which from an internet search I am assuming is made by Chevron. Unfortunately, a search here on powerstroke.org for "dello" doesn't return any information as most people say to run Rotella. Does anyone have any suggestions on if I should go this "dello" route? My second question is regarding the weight. I"ve noticed a lot of people on here saying they run Rotella 5 - 40. In the owners manual it says I should run 15 - 40. What are your thoughts on this? My third question is regarding the CPS. I have no idea if the CPS has ever been changed in the truck. Since the CPS's are cheaper now should I go ahead and purchase 2 of the new grey ones and replace the one currently in the truck? I see a lot of people saying to just get a spare. Is there any advantage in changing my existing one with a new one if all is well? My fourth question is about tires. I will need to get new tires before next winter. What is the max tire size I can use with the 4" lift currently on it? I don't want any rubbing etc. The 33's on it now seem small in comparison to the truck. Thanks everyone for your suggestions and hopefully someday I will be experienced enough to answer some questions myself! Mark |
Howdy and
![]() I run shell rotella 15w40. I've run delo before. Both to me are good oils. Just as long as it is 15w40 you should be good. It would not be a bad idea to carry a spare CPS. as for changing the one that is in there unless you are experiencing problems I would just leave it alone. with a 4 " lift 35-36 inch tires should fit with no problem. |
Also the 5w40 you see people running is full synthetic
Welcome to the site!!
I run what ever oil Jiffy Lube put in her... 37's on my 4" lift!
Thanks everyone for your replies and the welcome!
Welcome to the .ORG!
glad to have you here!
Dude...........c'mon, really????
I wouldn't trust them to fill my washer fluid! chris |
