Old 07-16-2007, 06:35 PM
dieselpower99 dieselpower99 is offline
PYROMETER PROBE PLEASE HELP
where is the best place to install the pyrometeer probe
Old 07-16-2007, 06:42 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
The best place is your exhaust manifold. Use the drivers side as its less of a run for the wires.
Old 07-16-2007, 06:44 PM
Here is some good directions for ya with pics.3-Gauge Install Pictures
Old 07-16-2007, 06:47 PM
thanks help alot i ordered new evolution surley they will tell me what size of tap to use
Old 07-16-2007, 06:52 PM
You should get install directions, but on there website they say 5/16ths hole 1/8th NPT for the tap
Old 07-16-2007, 06:55 PM
Marty Marty is offline
International Threat
Anybody locally that wants to do a video writeup lemme know on gauges - that's one writeup I wanna do for the site soon!!!
Old 07-16-2007, 07:25 PM
Rob Rob is offline
Free Faller
Send a message via AIM to Rob Send a message via MSN to Rob Send a message via Yahoo to Rob Send a message via Skype™ to Rob
man we should have done it when i installed my set, we could have used pics or something, i know im not local but it could have worked!!
Rescuediver Rescuediver is offline
SMOKE ROLLER
I agree exhaust manifold is the only way to go. Temps differ vastly if you put it anywhere else...
Old 07-17-2007, 03:32 AM
drfranktate drfranktate is offline
And the exhaust manifold is very easy to drill/tap. MUCH easier than plate steel. It won't take you more than 10 minutes.
Old 07-17-2007, 06:58 AM
MountainGarage MountainGarage is offline
use a vacuum/shop vac next to the whole while you are drilling. Then put some wheel bearing grease on the tap to hold on to the shavings. Don't want cast iron shavings getting back into the cylinders some how. Not likely, but better to be safe....
