  #11 (permalink)
Old 07-17-2007, 05:18 PM
CSIPSD CSIPSD is offline
Originally Posted by MountainGarage View Post
use a vacuum/shop vac next to the whole while you are drilling. Then put some wheel bearing grease on the tap to hold on to the shavings. Don't want cast iron shavings getting back into the cylinders some how. Not likely, but better to be safe....
No offense meant but how is that going to happen?
Your drilling the EXHAUST side... Any shavings that do FALL UP (remember gravity here people ...) will blow thru the EXHAUST side of the turbo with no effect at all ...
  #12 (permalink)
Old 07-17-2007, 05:50 PM
Justinlw Justinlw is offline
Send a message via MSN to Justinlw
Didn't stump already do a writeup with pics? I saw it on here somewhere...
  #13 (permalink)
Old 07-18-2007, 03:26 AM
drfranktate drfranktate is offline
I didn't have much success using this method. After drilling the hole, I snaked a magnet in there (I bent one of those retractable magnetic get-stuff-outta-tight-places tools) and it picked up all of the shavings.
  #14 (permalink)
Old 07-18-2007, 10:43 AM
dieselpower99 dieselpower99 is offline
this guy is a smart buy i was thinking **** i am ****ed up thinking that the exhaust runs back though turbo and cylinders haha
  #15 (permalink)
Old 07-18-2007, 02:21 PM
Marty Marty is offline
International Threat
I'm the guy that does video write ups. Everybody had a "how-to" or "picture writeups" but how many people have VIDEO writeups like you see on the TV show "trucks" or "powerblock TV" etc...
That's where I come in ;-)
  #16 (permalink)
Old 07-18-2007, 02:29 PM
cptpablo cptpablo is offline
Wear saftey glasses!!!!!!!!! I had a piece off steel in my eye for 3 days before the eye Dr. had to scrape it out. I felt like a D.S. just because i didnt take 2 seconds to put on saftey glasses.
I got the shavings out by magnitizing an alen wrench and sticking it in the hole.
  #17 (permalink)
Old 07-18-2007, 02:54 PM
Southpaw Southpaw is offline
1/20/2013
Hey Martin,
If the timing works out, etc.. maybe i'll "let" you do your video doc of my gauge install??
You're looking for someone, right? I'm 150miles from you, but i'm not in big rush either, I haven't even ordered them yet. I'll probably install them in Aug. sometime.
chris
  #18 (permalink)
Old 07-19-2007, 07:29 PM
Originally Posted by pwrstrokn View Post
Hey Martin,
chris
Well tomorrow I'll be doing the install for the video writeup but I'll still install your gauges for you if you want.
Then we can run it at the track and see how it does!
