Old 07-16-2007, 03:55 PM
dieselpower99 dieselpower99 is offline
The new evolution please help
i order new evolution i had old one how hard is it to install what all is there to install is it pretty cool i am pumpted to get it let me know ASAP
Old 07-16-2007, 05:36 PM
Southpaw Southpaw is offline
1/20/2013
I might be missing something here, but i've got an older edge evolution.
It's a programmer, not a chip so there is no "installing" it.
Just plug it in to the consumer data port, and follow the instructions on the screen.
chris
Old 07-16-2007, 05:42 PM
1/20/2013
Make sure you put your old one back to stock first.
Old 07-16-2007, 05:53 PM
already did it what else is there todo tho
Old 07-16-2007, 06:00 PM
1/20/2013
As far as I know, That is it.
Return the old one to stock, and plug in the new one and program it.
I don't think it would have to be reflashed, but i'm not sure.
May want to wait for some of these other guys to post. I've never changed from one programmer to another.
Good Luck!
chris
Old 07-16-2007, 06:02 PM
do i keep it plugged in i mean how does this new one work
Old 07-16-2007, 06:20 PM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
i believe you keep it plugged in to get the info on the attitude display....
Old 07-16-2007, 06:21 PM
1/20/2013
How new is it?
Did they redisign it?
If it is a programmer, you do not leave it plugged in.
You just plug it in, pick the setting you want to run on, and unplug it.
The programmer will guide you through the whole thing. It's real easy, and takes about 5 min.
Where did you buy it from?
Old 07-16-2007, 06:41 PM
i upgraded though edge it will cost me 300 to get everything i mean like there is the egt probe to install does anyone have it that i can talk to i want to know what to do to install it
Old 07-17-2007, 09:32 AM
pullmaxdude pullmaxdude is offline
Send a message via Yahoo to pullmaxdude
It is very easy, Plug into the OBII conector, Route the cable under stearing column and up to the dash, Install the pod mount, plug in to the monitor. Yes it does need to remain pluged into the OBII. Next drill and tap the manifold @ bottom driverside for EGT probe, route that cable back to the OBII area as it will plug into the plug from the monitor..........VERY SIMPLE
