  #11 (permalink)
Old 07-12-2007, 06:28 PM
mech2161 mech2161 is offline
A 454 at 500hp... yes it's easy. How hard is it to make 1000ft lb tq with a 454?
  #12 (permalink)
Old 07-12-2007, 06:38 PM
Stroked95 Stroked95 is offline
I thought dockboy said he was 758 on giggle gas? But now skaterboy has him by 1hp??
  #13 (permalink)
Old 07-13-2007, 06:21 AM
floundergigging floundergigging is offline
Torque is what sets you back in the seat
  #14 (permalink)
Old 07-13-2007, 08:13 AM
fulloutpwr fulloutpwr is offline
Where you guys seeing this talk abour a CR conversion kit? Searched through all the forums I know of and nothing.
  #15 (permalink)
Old 07-13-2007, 11:09 AM
CSIPSD CSIPSD is offline
Its coming... not much being said on it but it is out there.
  #16 (permalink)
Old 07-13-2007, 12:17 PM
TwinTurboStroker TwinTurboStroker is offline
Now, on to the race truck
I'm still new to owning and learning more than just the basics about diesels, I have heard that common rail is the way to go..... My 1st question is why is that? more pressure? and the second is what's the difference between the CR and the system on the 7.3? But anyways sorry for the slight here is a bump to finding out what 7.3 has made the most HP numbers...
  #17 (permalink)
Old 07-13-2007, 08:10 PM
Marty Marty is offline
International Threat
Dockboy's up there as far as #'s go... I think he dyno'ed at a max of 756 on NOS, and puts out under 600 on #2. I spoke with him, and I'm not sure he wants me to repeat this, but basically he is getting tired of breaking bottom ends which cost several thousdand dollars to fix each time.
There is a guy in NJ who's online handle is "Thuglike" and IIRC he out did Dockboy on the dyno, but not at the track. I almost had the oppurtunity to meet this guy, but he never showed up @ the track last fall. Hopefully I'll meet him August 11th @ the track.
Cale's truck @ BTS is the fastest fullweight 7.3 afaik, but it's an OBS single cab that runs 11.5's or better. He's dyno'd beyond 756, but I'm not sure exactly what his #'s are.
Unless you have 30k to spend - don't push your motor that far. Chip it, injectors, turbo's, other bolt-ons and stay away from the giggle gas!
  #18 (permalink)
Old 07-13-2007, 09:47 PM
Lowboy Lowboy is offline
Running a hydraulic actuated injector in the Powerstroke is somewhat like controlling spark timing on a gas engine with a rubber band. It works OK at slower engine speeds but up at higher engine rpm's the fuel cycle beginning point/cutoff point is giving everybody performance headaches to say the least. The 6.0 injectors had better performance electronics but still dosen't control precise fuel delivery like the common rail system.
That's the main reason we don't see exorbitant HP numbers with the 7.3's. Than we try to make up for injector downfalls by using excessive drugs and stuff busts. I've used the "hand basket" myself picking up parts.
IMO, Cummins ain't the answer. Common rail is..
  #19 (permalink)
Old 07-14-2007, 02:44 AM
driximus driximus is offline
This definatly calls for a Re Adjustment of Plans I might hold off on Big Oil when i get back.
  #20 (permalink)
Old 07-14-2007, 04:28 AM
Southpaw Southpaw is offline
1/20/2013
What track?
