What next...
I finally got gauges and had chip/exhaust, just wondering what mods should be next and what you guys think are a waste. Just trying to figure out how much $$ for the next step. Going to do the zoodad, soon, btu that doesn't cost anything.
You can do all the little stuff just more or less to fill in the sig... Zoodad, CCV mod, IAH delete, a DIY exhaust brake and TC lock up switch, or a SP diesel exhaust brake TC controler, Tighten up the wastegate a bit, remove the foil from the drivers side IC tube...
Cost wise stuff... A BTS valve body in the tranny... a 6 pos chip will really open her up... Turbo upgrade if your thinking you might do injectors some day, if not a ATS housing... |
Whoa, sounds like alot. I know the zoodad. Heard some about the CCV, any write up or how to's anywhere? IAH? and a how to? tighten up the waste gate? haven't heard of that one.
Later on, depends how long the tranny will last, want to upgrade the turbo and injectors/hpop. I forgot all about the foil delete, wanted to do that same time as zoodad I have a 150k on it, not sure if its the orig tranny, is a valve body worth the $ or just put the $ toward a new TC or tranny |
