White/gray smoke issue - Ford Powerstroke Diesel Forum
Old 01-28-2011, 01:33 PM
O.I.F. Combat Vet 11B
blueish/gray smoke issue
I am in the processs of still hunting down my smokeing issue under light throttle and take off. I have tried just about everything I can think of. I just pulled all 8 injectors and the orings and copper washer look fine..... Any other ideas on my I am having these issues, injectors only have 8k on them or so and were from rosewoods injectors premium rebuilds.
Old 01-28-2011, 02:56 PM
Check your MAP sensor. It tells the PCM what load is on the engine and how much fuel it needs. It's other job is to control smoke by limiting fuel flow during accerlation until a specified boost pressure is achieved.
Old 01-28-2011, 06:37 PM
I am getting no codes at all, could it be bad or not working properly and not throw a code?
Old 01-29-2011, 06:45 AM
The MAP sensor recieves 5 volts from the PCM to monitor the "load" on the engine. IF I remember right the voltage back to the PCM increases as the manifold pressure increases. The way International programs the 7.3 in the PCM allows for a wide range of operating parameters from the sensors without throwing on the check engine light. If the MAP sensor is bad or not reading right the PCM will determine a value for the MAP according to engine conditions it sees from the other sensors. I would check the voltages and see if you do have 5 volts going to the MAP and that the voltage reading does change according to the drop/rise in manifold pressure.
Old 01-29-2011, 06:51 AM
sooo close lol
Hes correct it gets a 5 volt reference signal from the PCM, it then goes thru the MAP and returns on the signal line with a reading from 0-4.9V .. basically anything over 2.5V is usually boost..but on our engine due to no vacuum being created its just there for boost and BARO..
So basically if it sees 2.5V it sends that signal to the pcm, Pcm looks at it and lets say 2.5 = 10psi, it adjusts fuel and timing accordingly..make sense?
However..i havent seen many of these fail.. You have a bigger turbo etc?
Old 01-29-2011, 10:15 AM
Originally Posted by 03_Turbo7.3 View Post
sooo close lol
I have stock turbo but do have stage 2 nozzles.
Old 03-02-2011, 04:03 PM
Hey there you ever figure anything out with your truck?
Old 03-02-2011, 04:34 PM
not yeat but I think it is weak hpop. Got a srp1 coming in the mail. I can barely get to 2k icp in a 60-90 run and with the splits with stage two nozzels i am getting all the smoke
Old 03-02-2011, 05:20 PM
Ok well let me know if that works. Mine still does same thing with smoke every now and then.
Old 03-16-2011, 04:20 PM
I still have yet to figure this out, just blows a blueish gray tinted smoke on acceleration.
