Isspro EV2 and Performax Warning lights and Performax data logger - Ford Powerstroke Diesel Forum
Old 01-27-2011, 05:40 PM
As some of you know I test new gauges for Isspro... Got some new stuff coming out that I thought I would show you!
The black part plugs into your data lines for the Performax gauges, then you plug the thumb drive into it. When you want to record data you press the black button, and when you want to stop you press it again.
You can do this as many times as you want. Each time it is saved as a file on the thumb drive.
Once you are done for the day, you remove the thumb drive and plug it into your computer.
You can see the 6 files I made on this picture...
Then using this software you convert it to a excell spread sheet to look over the data or send it to anyone.
You do not need to have a gauge installed to data log the data, only need to have the sender installed and plugged into the ESP (brain of the performax)
Any questions feel free!
Old 01-29-2011, 06:13 PM
Good to know you are "in" with ISSPRO. I have a late 99 which I bought 1 year ago. I have triple ISSPRO gauges which were in the truck already. The transmission temp gauge does not work but it has power to it. What do I need to look for in diagnostics. I thought I might need the sensor on the transmission but I dont know where a part number is or where to look for it. Do you have any comments of what to look at? I really would like to get it working.
Old 01-29-2011, 06:43 PM
Wow... 3 days and one post...
Guess you guys are not interested?
As to your problem, Need to find out what kind of gauge it is, judging by the comments I would bet its an EV gauge. There should be small boxes mounted somewhere under the dash, each gauge (pyro and tranny temp) will have its own amp gauge.
Check the Amp boxes to make sure they are connected to power, ground and lighting. Then follow the sensor feeds from the AMP box down to the tranny.
The sender will be in the test port of the trans... See pic. Drivers side, just in front of the shift linkage.
Get back to me and I will help with what ever I can.
Old 01-29-2011, 10:23 PM
ok. either youre testing them side by side or i'm missing the point of two turbo gauges.... do they come factory set for certain pressures/temps and whatnot? or can you calibrate them yourself? Id be REALLY interested in a set so I wouldnt have to stare the gauges down at WOT or while pullin...
data logger seems cool but not my cup o tea unless i start buildin a race truck
Old 01-29-2011, 10:38 PM
Powered by Deez Nuts
they dont max out unless you were going to a specific reading. looks like they need recal.
Old 01-29-2011, 10:49 PM
He gets the spiffy prototypes... lucky b@stard....
Old 01-30-2011, 09:08 AM
Right now the EV2 gauges are being put out with the warning lights preset at levels we came up with as triggers. Later on there will be software to make them end user ajustable.
EGT comes on at 1240*, boost at 40#, Fuel Pressure at 25, Oil Pressure at 20 so on and so forth.
Performax has a function called Peak Recall, which by pressing a momentary switch all your gauges go to there max readings since the last time you cleared the memory. (Fuel Pressure and HPO Pressure go to there lowest readings)
I also have a ton of holes in my dash, and quite a bit of time invested in wiring, un wiring and stuff of that sorts... Its great, but not all rosey.
Old 01-30-2011, 09:31 AM
Sweet gauges. I am gonna get the ev gauges, how long till these gauges come out who? Also do they have a an idea on the prices
Old 01-30-2011, 10:29 AM
Look at the EV2 line up, the prices will be just a few dollars more then the EV2's are currently.
Talk to the vendors here, they can get them from Isspro now.
Old 01-30-2011, 10:31 AM
Awesome thanks for the info
