Disabling ebpv
can I just unplug that lil white plug at the base of the turbo? can i try moving the ebpv actuator by hand while its hooked up? I haven't been seeing quite right boost lately (no gauges, but seat-o-the-pants meter is showing low boost
) And when I really get on it and up in the 2k plus rpms alls I hear is loud hissing, the higher the rpm, the louder the hiss. I can hear the turbo spool (a bit) but it seems lacking too. I'm thinking its either a malfunctioning/stuck ebpv or a pre turbo/ intercooler leak, since any post turbo leaks would have no affect, right? If I can move the ebpv actuator, which way is open and which is closed?Thanks in advance, Jason |
sounds like a boost leak to me
Does your ebpv even come on in florida?
j/kI'm thinkin from what I've deduced through my searches (good ol google) that I can just unplug the pedestal and give it a shot... if the valve is the only power robber ive got, I dont want to have to do boots and up-pipes and all that jazz just yet! |
OK, went and unplugged the ebpv harness. This did help a bit, the weird bog down I was experiencing at around 1500 rpms is gone, but in the high end (like 2500 rpm and when under a load, like going up hills) I heard a lil bit off hissin. I'll take pics of intercooler boots and whatnot in the morning, see if yall can notice anything that im too inexperienced to pick up. But I did another test to see if I'm losing something... mods and setup are in siggy. Did a 0 to 60 (semi boosted launch, wound up to 1500 rpm in 2wd and let her rip) to 16.46 seconds, give or take half a second. Is it just me or is this SLOW AS MOLASSES!?!? My ICP still isnt fixed
but I doubt it would effect this THAT much... anybody else got 0-60 numbers with similar mods to compare?TIA ya'll |
ya man that is pretty slow i think that my grandma gets to 60mph faster than that! j/k i have an 03 ex 7.3 psd that does that same hissing noise almost sounds like a sqeeling noise like burning rubber and it does it right at 2500rpm in boost too. did unplugging the ebpv modual help that noise go away at all? i have a 4" straight pipe i wonder if that is making the difference?
whats an ebpv ? i deleted mine long ago. ha.
You check the up pipes for leaks?
Sounds like a boost leak, and a drive pressure leak. Did you unplug the EBP Valve at the base of the turbo, or the EBP Sensor at the front of the motor? |
Did you unplug this one?
yeah, i unplugged that one, at the base of the turbo. A pita to get to with them intercoller pipes there.
I need to crawl under the truck and check my up-pipes still. Its all mushy outside and I need a dang driveway or garage. My intercooler boots are greasy/oily too, I'll take pic, Idk if they could leak that much
