1.0 turbine housing - Ford Powerstroke Diesel Forum
Old 01-25-2011, 06:34 AM
1.0 turbine housing
Who on here actually uses the upgraded turbine housing on there stock turbo? If you got one how does it help or act differently from the stock housing?
Old 01-25-2011, 08:51 AM
Lowers drive pressures, lower EGT's.. A bit more HP on the top end...
Worked pretty good back then.
However, dont go invest a bunch in the stock turbo, only to upgrade to a 38r or something like that later.
Old 01-25-2011, 09:57 AM
Originally Posted by CSIPSD View Post
...However, dont go invest a bunch in the stock turbo, only to upgrade to a 38r or something like that later.
i dont have an SD but cant ee that much gain with just housing. might be money better spent on a 38r.
Old 01-25-2011, 10:20 AM
I actually got the housing from a blown turbo. A buddy on mine replaced it with a 38r, I have to pull my turbo so I was going to throw it on and try it. I want it for mostly sled pulling and racing to bring my egts down a bite. How's it act driving on the street. I've heard its heard to spool with
Old 01-25-2011, 10:26 AM
It will help with EGT's and drive pressures... Just keep in mind you still have a stock center section.
Who ever told you it was hard to spool is FOS... They need hit on the head with a tack hammer.
Throw a 1.15 housing on there and it would spool the same as the .84 housing with even lower drive pressures and EGT's.
Old 01-25-2011, 05:43 PM
im running an ats 1.0 housing it spools nice no probs here.
