Just rolled 100k, have a couple questions - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-24-2011, 11:52 AM Thread Starter
RHFDpowerstroke53's Avatar
Question Just rolled 100k, have a couple questions
hey guys, i had a couple questions about my 7.3. first off how long can i expect my injectors to last? i just rolled over 100,000. I installed my DP tuner with 98 and change so its still pretty new. Also i was wondering how long i can expect my leaf springs to last? I have a feeling i may have cracked one cuz the truck sometimes looks like it leans to one side. Thanks for your help
2001 F-350 XLT
'05 Conversion
DP-Tuner
Tuff Country 2.5in Leveling Kit
MBRP Muffler Delete W/ Homemade 5in tip
aFe Stage 2 Cold Air intake
Wicked Wheel
315/75R16 Mickey Thompson Baja MTZs on Procomp 6001s
RHFDpowerstroke53 is offline
post #2 of 8 Old 01-24-2011, 12:06 PM
E'sStrokr01's Avatar
My truck is knocking at 211K miles on stock injectors, etc. I treat the injectors to good clean biofuel mixtures B-20 to B-50 depending on temperatures where I live. Or regular diesel with Diesel Kleen, etc.
No real way of saying when the injectors will go but you're in really good shape at only 100k miles. That truck is still new in many ways with only 100K........so have fun breaking it in! I personally would drive it and not look back! Just keep good fuel and/or additives in there
E'sStrokr01 is offline
post #3 of 8 Old 01-30-2011, 07:00 AM
Quoted: 2 Post(s)
My 02 has 105K on it and runs GREAT! I tow VERY heavy and don't have a spring problem. I'd be checking the pavement it's on or load in the rig. I too have a DP tuner and love it. Changing the fuel filter regularly is the best thing you can do for those injectors.
02 F350 CC 7.3 PS, auto, 6x6, 4.10 gears LB. AFE stage 2 intake, 4" AFE SS exh, 6.0 atf cooler, DP tuner with five stages
Eng Temp gauge, EGT guage and Trans temp gauge. J.Woods valve body ATS turbo housing. Cooling sys filter & waterless coolant. NON WORKING POS FASS fuel filter sys. Brightbox headlites. I don't care what they say "There's no replacement for displacement."
Don't believe statements about anything being better than a 7.3
GOD BLESS AMERICA!!!!
Bart_3500 is offline
post #4 of 8 Old 01-30-2011, 08:09 AM
175k on stock sticks.. they go awhile for sure.
Dietoremain is offline
post #5 of 8 Old 01-30-2011, 08:48 AM
STRKTHS73's Avatar
Send a message via AIM to STRKTHS73
i had an 02 went 275k on my stock injectors and leafs an i hade an edge chip in it since it had 80k only thing i went through was a turbo at 160 and a tranny at 200k
06 F-350
4" turbo back silverline exhaust
KMC XD series spy wheels
35" toyo m/ts, 5% window tints
4.5 rough country lift
triple pillar egt, boost, and trans temp
edge cts insight
CAT coolant swap at 30k
Sinister Coolant Filter
SCT X3 with custom tunes by vivian at QT
STRKTHS73 is offline
post #6 of 8 Old 01-30-2011, 10:09 AM Thread Starter
thanks for your help guys. Idk what my bud was talking about when he said only 120k on my sticks. And ill have to check my leafs. If i find a cracked one i like it'll be time to lift it.
2001 F-350 XLT
'05 Conversion
DP-Tuner
Wicked Wheel
post #7 of 8 Old 01-30-2011, 12:29 PM
Let's go B's!!!!
Southpaw's Avatar
Feedback Score: 5 reviews
How bad is the lean? Mine leans almost 1" lower on the drivers side. It did before and after the lift. A LOT of Super Duty's have that drivers side sag. It's really common, but it's usually an inch or less and is unnoticed a lot
Chris
2002 Crew Cab Long Bed
4" BDS, 35x13.50 Cooper STT on 20x10 Black Rockstars, and other stuff.....310,000 miles and counting...
2 Thessalonians 3 v.6-15
Southpaw is offline
post #8 of 8 Old 01-30-2011, 12:33 PM
nine6stroker's Avatar
Quoted: 35 Post(s)
My injectors still passed buzz & contribution tests at 200k with flying colors. I wouldn't worry about yours for a good while
1996 F250 7.3 PSD 4x4 - "Dally"
281k miles
BDP stage 1's, T500 HPOP, TS6 chip, KC38r turbo, stock trans and fuel
Sitting on 2006 F-350 axles and suspension
nine6stroker is offline
