7.3 Engine cleaning?
Hello my new trucks engine is really dirty can i clean it like i would a gasser? degreaser + pressure washer while its cold?
I have power-washed mine, I used Gunk engine degreaser, the only thing I covered up was the exposed air filter element.....Fred
Yea, just did mine. Used Castrol Super Clean, let it sit 10 mins, and used the Pressure Washer. I tried to avoid the alternator, but the rest was fair game
Also, I turned down the pressure on the pressure washer, doesn't take much to blow a seal ![]() Oh yea, I am not responsible for any incidental damage to you, your vehicle, or any other property |
Your sig says CCSB?
just don't use a rag with carb clean on the stickers, accidently wiped the build date right off my valve cover
I need to do this to mine once the weather warms up a bit.
I use greased lightning and a pressure washer. deffinetly do it when motor is cold the quick cooling of water on the turbo could crack the housing.
