Fuel heater needed? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-23-2011, 11:25 AM Thread Starter
Fuel heater needed?
I have a buddy who has a 99 and the fuel heater wire thing (inside the bowl) is busted loose.
Question is does he even need the fuel heater? we are in central Texas so winter is really not an issue.
thanks
2004 F-350 CCLB 6.0 4X4 1997 F-350 CCLB 460 4x4..
Past--2008 F-250 CCSB 4x4.....Past CTD's 2001 QCLB 2500 4X4 5.9-2006 QCSB 2500 4x4 5.9 -2006 Mega 3500 4x4 5.9 DRW Wake Up America
TEX235 is offline
post #2 of 6 Old 01-23-2011, 02:53 PM
Most likely don't need it in Texas but you can pick up a new one up from rock auto for about $25.
engnerdan is offline
post #3 of 6 Old 01-23-2011, 10:57 PM
i doubt it, unplugged mine months ago, no need here.
Dietoremain is offline
post #4 of 6 Old 01-24-2011, 03:19 AM Thread Starter
thanks for the input
TEX235 is offline
post #5 of 6 Old 01-24-2011, 04:39 AM
chrispaine's Avatar
I am in Michigan and when mine popped the fuse I just unplugged it and haven't needed it yet. (knock on wood) I should replace it if it only runs $25.
2000 F250 7.3L EX.Cab Short Bed -05 Front end w/ HID's - Leveling shackles - Wicked wheel - Dipricol gauges - FORD AIS intake - Foil Delete - LINE-X Rockers - CCV dump - 315/70/17 BFG A/T with Eagle Alloy 197's - ELC w/ coolant filter and around the belt hose - PHP Hydra - Hpress oil x
On the way--
-Fusion front bumper - ATS 3" fender flares
chrispaine is offline
post #6 of 6 Old 01-24-2011, 09:02 AM
CSIPSD's Avatar
No need for the fuel bowl heater anywhere IMHO. The volume of fuel it would heat when it works is too small.
I dont even have a fuel bowl, and have no issues down to -20.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
