HPOP o-ring leak question - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-21-2011, 12:27 PM Thread Starter
04king_stroker's Avatar
ive already ordered my oring kit and its on the way, my question is do I let disconnect the line/fitting and just let the oil drain so I can clean the threads and if so once shes all put back together do I just top off the hpop resevoir. Ive head of people replacing the oring taking it for a ride and then they shut it off and it doesnt start again. andy help would be greatly appreciated thanks.
2004 F-250
Mods: Sct x3 with custome tunes, Zex Nitrous, AEM intake, Straight exhaust with 7" tip, 07 front end conversion, Recon lighting, 09 Tail Gate
04king_stroker is offline
post #2 of 8 Old 01-21-2011, 02:34 PM
layson's Avatar
Quoted: 82 Post(s)
Just unthread the line from the HPOP, stick a new Oring on there, let the oil drain out of the hose while you are doing it. Then snug it down with a wrench. You probably won't see your reservoir go down at all. It will just take a couple good 20-30 second cranks to get her going.
If you pull your HPOP, then yes, you will need to top it off.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #3 of 8 Old 01-21-2011, 03:12 PM Thread Starter
so dont bother with the loc-tite just throw on the oring and go?
2004 F-250
post #4 of 8 Old 01-21-2011, 03:19 PM
layson's Avatar
Quoted: 82 Post(s)
I didn't use any locktight. Part of me doesn't like to use it, I have seen it take the threads right out of a pump before.
Quote of the Day:
layson is offline
post #5 of 8 Old 01-21-2011, 03:21 PM Thread Starter
so just throw on an oring and go huh? did you buy the ford kit or can I get one from autozone or oriellys thanks for all the help
2004 F-250
post #6 of 8 Old 01-21-2011, 04:13 PM
03_Turbo7.3's Avatar
i followed the Ford steps..never had any issues yet..
05+ coils, 10 Rear diff, box, tailgate, lights, bumper, Full 07 front harley swap...the list is endless.
AS IM RARLEY on here anymore...have a question ?? EMAIL ME
gladly answer any of your questions. OR search me on facebook. ill help out anyway I can !
updated as of OCT 28/2013
03_Turbo7.3 is offline
post #7 of 8 Old 01-23-2011, 08:22 AM
prowirenut's Avatar
Just be real careful when tightening the hose fitting back into the pump. Remember the pump is aluminum and the fitting is stainless steel. I learned the hard way. I must have slightly overtightened it or it was weak from previous owner and when I took it out for a drive it blew the hose, fitting, and the threads right out the side of the pump. So I had to buy a new pump, my cheap o-ring fix wound up costing me close to a grand.
2002 F-250, 4X4, SB, CC, 7.3 Diesel
6.5" Pro-Comp lift
Pro-Comp MX-6R Shocks
37" X 13.5" Mickey Thompson ATZ's
GTP 38 Turbo upgrade
Snow stage 3 water/meth kit
AFE Intake
4" Magnaflow Exhaust
SCT Custom Tuner
SSBC Brakes and Calipers
Powerslot drilled & slotted rotors
Airlift Air Bags w/Onboard Compresser
Reese 5th Wheel Hitch
Carbon Fiber Dash Kit
Transmission by Scott at MASS Diesel
4.30 Gears
HornBlasters Train Horns
prowirenut is offline
post #8 of 8 Old 01-23-2011, 08:46 AM
dont wanna sound like a dick here but...torque settings are made just for this reason..
