Intermittent Electric Windows????
Sometimes my entire window switch will go dead. None of the windows make a sound. If I turn the truck off and restart, sometimes that will fix it. I'm thinking a relay might be bad. Where do I find it?
It is 20* out and the driver's window is halfway down
Mine has done this. It was a loose wire at the switches on the drivers side controls. To check them gently pry up on the front (side towards the front of the truck) of the black panel that the switches are mounted in. Then lift up an pull forward. Check for loose wires going into the bottom of the switches. Hope this helps.
Well I just tried that and no loose wires or connectors. However I did hear a clicking like a relay under the dash. Will have to check that out after a cold ride home!
Thanks for your input. |
