performance, battery, mileage - Ford Powerstroke Diesel Forum
Old 01-21-2011, 08:22 AM
Talking performance, battery, mileage
Can low/weak/bad batteries cause performance and mileage issues. Just asking out of curiosity.
Old 01-21-2011, 01:36 PM
Typically if the batteries are bad, it won't even start or just barely. I would guess it may slightly effect performance, but I doubt you would notice it. Most likely it just wouldn't like to start...
Old 01-21-2011, 09:03 PM
Low batteries will cause the alternator to work harder resulting on more load on the engine. You'll have a hard time measuring the difference, and you won't be able to feel it.
Old 01-21-2011, 09:13 PM
Send a message via AIM to tonypagnano
the battery is really only for starting and grounding, the alternator takes over everything once the truck is running
Old 01-21-2011, 09:16 PM
'Merica
should be good to go if you can start it. other than possibly leaving you stranded when you need it most cause it wont start.
