transmission fluid change. how to? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-19-2011, 03:54 PM Thread Starter
Jleof250's Avatar
Ok. I need a transmission fluid change since the line to the cooler was leaking and fluid was low and I have no idea what staff they had in there. I removed the plug, drain the fluid bud there is no plug in the converter todrain the fluid, how do I take all the fluid out. Thanks in advance.
Jleof250 is offline
post #2 of 7 Old 01-19-2011, 04:01 PM
Josh99's Avatar
Take it to a shop, worth the little bit extra you will pay. Mine cost about 95 bucks to get changed.
- Zoodad
- Wicked Wheel (kills MPG)
-4" straight pipe dumps in front of rear tire
- Tuned by Power Hungry Performance
- Cold air
- Custom brush guard/winch mount
- Limo tint
- CB
- JVC head unit
- Warn Hubs
- 6637
- 45k Tru Cool + stock
Coming soon-
- 16k Warn winch/air compressor
- Leveling springs (WTB!!)
- Tranny build
- Forged rods
Josh99 is offline
post #3 of 7 Old 01-19-2011, 06:18 PM Thread Starter
Jleof250's Avatar
It is a little to late, I replace the line to the cooler that was leaking an fluid is out, the last thing I did was look for the converter plug and it was not there and the lowest price around to do everything not including fluids was $ 130. I had no choice
Jleof250 is offline
post #4 of 7 Old 01-19-2011, 06:26 PM
IBEW Journeyman Lineman
PolarBear's Avatar
If you have already drained the pan, then put back in the amount of fluid you already drained. The you can remove the return line from the cooler at the trans. put some tubing on line and put it in a bucket. Have someone run the truck and shift the gears while you add more oil as the trucks internal pump gets the old oil out. When you see clean oil coming out then its flushed. The just have to get your fill level correct.There are some really good writeups on this with detail and pics. I flushed my 99 this summer with Amsoil doing that process and it worked out good.
2012 F350 XLT CCLB 4x4 6.7
PolarBear is offline
post #5 of 7 Old 01-19-2011, 06:44 PM Thread Starter
Jleof250's Avatar
Wish one is the return line on a 2000? The one that connect at the front of the transmission or the one that connect on the back of the transmission?
Jleof250 is offline
post #6 of 7 Old 01-19-2011, 06:51 PM
PolarBear's Avatar
The return is at the back on the trans. When you take that one off it may lose a little bit of fluid but not much. When the truck is running though it shouldn't have any coming out.
Changing ATF: 7.3L PowerStroke Engine and 4R100 Automatic Transmission. - Diesel Forum - TheDieselStop.com
post #7 of 7 Old 01-19-2011, 09:58 PM
did mine with truck running, pulled a line, drained some, added some, and so on, poured a whole 5 gal bucket in eventually and it was coming out clean. lol.
Dietoremain is offline
The Following User Says Thank You to Dietoremain For This Useful Post:
Notw (10-05-2014)
