engine compartment cleanup advise
ive got a question about cleaning the engine compartment.other then probably pissing off my neighbor (which i dont care about considering i gotta listen to their kid attempt to learn how to play the trumpit. as he plays marry had a little lamb and jingle bells at the same time, while im BBQ on my deck
) does anyone see anything wrong with spraying it down with brake cleaner to remove the dirt and crud??
I use simple green & a garden hose, might use some of the gunk on heavy stuff or a brush with the simple green. Just remember there's a lot of elect sensor & stuff on the engine
sounds stupid but I always have used scrubbing bubbles on my engines and it works great
forgot to mention, walmart bags on the electronics and alt
brake cleaner will melt plastics
i use simple green let it soak and rinse with a garden hose when engine is cold |
i dont bother, no need for all that water in there just to be kinda clean....
Castrol super clean works great
not sure what kind of brake clean you are using but no it doesn't. Just leaves a nasty finish on pretty much everything.
Use an engine degreaser and multipurpose cleaner/soap water. |
what about purple power? or will that damage seals?
I've used it with no probs
