What year is the best for the 7.3L 99-03
Hello everyone I have been looking at some 7.3L powerstrokes. I am trying to get some input on what is the "best" year and main issues to look for in these trucks/stuff to watch out for while shopping. From what I am grasping 200K miles is nothing on a properly maintained motor. Any input would be greatly appreciated.
![]() depends on what you want. i think the biggest difference is Forged rods vs. PMR. 99-00 had forged, and some 01's did as well. but youll have to check the serial or look inside the block to be sure. early 99 had some quirky things, 15* HPOP, smaller injectors, 4x4 parts, ecu etc. nothing bad, just differences in power, and parts availability. they can be modded to reflect a late 99+. late 99+ has 17* HPOP, etc. so in durability and such my opinion would be a 00. but if your not powerign up more than 400hp or so. then any of them would be fine. what to look for: try and do a cold start, check the turbo fins for damage, if you see turbo damage then beware. check for leaks and post them here, most leaks aren't a big deal. see if you can get service records. if your really anal then get a compression test. check the front end for wear as well. are you looking for an auto or manual? what is your goal with the truck? |
2000 is my pick
honestly, for most who are gonna do just intake, exhaust and a chip any of them work nice. the 02 and 03 have really nice interiors compared to the older ones. they also have good cupholders... I have a 00 and love the crap out of it, but have friends and family running 7.3's from early 99 up to an 03 and they are all awsome trucks. just a little different. find a clean one that starts nice and runs well.
i dont recall exact links. but there are a few places (here too i think) that have a range of serials that had forged and a range of serials with PMR's (Powered Metal Rods). i think dieselpowermag has them somewhere as well. but their search feature is worthless.
DMAX injector issues are limited mostly to the LB7 (01-04.5). as for PSD as long as the rig has been cared for injectors should be fine. they can wear out though. but if good oil was put the truck on schedule then they should be ok. if you know anyone that has the AutoEnginuty software with Ford Package, they can do an injector buzz test and CCT (Cylinder Contribution Test) i dont have the software. but that will tell a bit about injectors. many people go 300k + on the same set of injectors, or only changing a couple. our injectors are hydraulic, they use the motor oil as fluid. some 01, and all 02-03 PSD's will have PMR's. i dont know of any solid trucks for sale in the area, but i usually keep my eye on craigslist. since your close i know the weather your in. if possible, i would prefer shopping for a diesel when the truck is cold soaked. the colder the better. it gives yo an idea of the conditions of the glow plugs, batteries, glow relay, injectors, and compression. if the glows or relay are out then youll have trouble. but if they are good and still has trouble then there could be issue elsewhere. |
The whole PMR -vs- Forged is just nonsense.....
Unless you have plans to dump thousands of dollars into engine performance it's not going to be ANY kind of issue for you. I say, there IS no good/bad 7.3s, buy your truck on condition and configuration alone. Look for a good deal in the truck you want with the Body-Cab-Drivetrain you can afford and don't worry about "throwing" rods that, really, Aren't breaking for anyone
There is a 2003 7.3 crew cab short box for sale by me, its black with tan leather, only 87,000 miles, nice cap. They are asking 22,000 but you could probly talk them down
![]() my pick is late 99 - 03 (even though mine is a E99 )
