Air Horn mounting location - Ford Powerstroke Diesel Forum
Old 01-15-2011, 01:05 AM
Wondering where you guys have your air horns mounted, and your compressor/tanks, I would like to put it into a toolbox in the bed, but I have been looking at toolboxes, and they are freaking expensive, gonna be cruising CL.
Old 01-15-2011, 01:11 AM
I've got my horns mounted on the frame rail just behind the rear door, and my compressor and air tank in the tool box, but you don't have to mount the compressor and tank in a tool box, they'll be fine on the frame rail, just try to tuck them up close to the floor board of the truck
Old 01-15-2011, 04:49 AM
I mounted my horns and tank on frame rails under cab and the compressor inside the truck behind the back seat.
Old 01-15-2011, 06:21 AM
There are TONS of pics here (I know I've uploaded mine ). Do a Search
Old 01-15-2011, 07:06 AM
See sig pic. On the frame rail. Compressor is further up on the frame.
Old 01-15-2011, 10:56 AM
If you look hard enough, it's easy to find a toolbox on craigslist for $50-100
Old 01-15-2011, 02:46 PM
Found a nice looking one for $60 for a tacoma, might be able to modify to fit 69'' width...
And I thought drilling the frame was a bad idea? Or at least the old man said he wouldn't do it.
Old 01-15-2011, 02:50 PM
If you do some peeking around there should be some holes already there that work. Otherwise you can make a bracket that attaches to those holes.
Old 01-15-2011, 04:12 PM
OK
Old 01-16-2011, 07:43 AM
here ya go
comp. is under the right front door
air tank is under the right rear door
horns are under the right side front of bed on frame
just my version
